Asko 12505 (10 yrs old) front load washer sometimes wont spin
Sometimes setting 3 on the dial goes through normal wash /rinse /spin and sometimes it stops after the wash, and wont drain which somehow prevents spinning. If I drain manually and then go to short spin or drain then the pump will start up and spin. It doesnt do this all the time, just sometimes. the other times it goes through a full normal cycle. Any help? Thanks RF
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Asko washer W6324. Ran two loads with no problems. These used the SANI setting (wish I could control the water temp by temp settings and not fabric descriptions). New load of delicates. I set it to woolen...
Try to press the start/stop button for at least 3 seconds. This should reset the started cycle, and you can make a new choice. If this dont help, it could be a faulty control board
Sep 29, 2013 | Asko Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Need information about an old ASKO 10604 washing machine
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Jan 23, 2009 | Asko W6021 Front Load Washer
Randomly incomplete washing cycles
SOUNDS LIKE YOUR DIAL/TIMER POSSIBLY HAS A STRIPED COG ON EITHER THE DRIVE OR WHEEL GEAR
Apr 28, 2007 | Asko W6021 Front Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
