Question about Bosch Range Vent Hood Halogen Lamp - 423765
Removing halogen lamp from bosch range hood - Bosch Range Vent Hood Halogen Lamp - 423765
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
Why does one of the halogen lamps burn out frequently?
Halogen lamps draw considerable current. There may be some defect in the socket such as cracked ceramic or damaged wiring contributing to short life.
Apr 20, 2016 | Zephyr Kitchen Ranges
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
I need a halogen bulb to replace the original one in my nexstyle range hood
So where do we buy the bulbs? We've been looking for ages. Thanks.
Sep 23, 2012 | Kitchen Ranges
DA 399 mEILE RANGE HOOD CANT GET OLD GLOBE OUT TO CHANGE HALOGEN 50 WATT
Remove the grease filters. This will expose the two screws that hold the lamps in. Turn the screws anti clockwise until the lamps drop a little. Twist the lamps gently anticlockwise to release them from the fittings. My instruction manual says reverse the procedure to insert new lamps. Haha. Good luck and be careful.
I had a lot of trouble getting the lamps back in. So much so that I have somehow damaged the fittings or wiring and now have to have a repairman out.... looking at $150 plus just because a light blew!
Feb 01, 2011 | Microwave Ovens
I need to repalce one of the bulbs in my Miele Kitchen Hood, but I cannot work out how the bulb is removed. How is the bulb located? Should it screw out or just pull out? I don't want to force it in case I...
Remove the stainless steel outer filter
(see "Cleaning and care").
Pull the halogen lamp out of its
socket. Take care not to let the lamp
fall onto the hob below.
Insert the new halogen lamp into its
socket and carefully push into
position.
On the link below on page 27 tels you how.
http://www.miele.co.uk/Resources/OperatingInstructions/DA%20249-4.pdf
Now if that is not your hood please find the model # and you can get the manuakl on this link below.
http://www.miele.co.uk/customer/OperatingInstructions.aspx
Good Luck and please rate 4 thumbs up for the free answer
Aug 11, 2010 | Miele DA 249-4 Kitchen Hood
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Bosch Range Vent Hood Halogen Lamp - 423765 Logo
106 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
