Question about New World E90DOa Electric Double Oven
Oven my new world oven and grill not working
Oven and grill stopped working suddenly rest of cooker is fine
4 Suggested Answers
SOURCE: New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Posted on May 04, 2008
SOURCE: new world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Posted on Nov 02, 2008
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Jan 06, 2010 | Ovens
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Hi
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
New world tgo 70 grill
Aug 14, 2008 | New World G60m Gas Single Oven
New World E90DOa Electric Double Oven Logo
27 people viewed this question
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
