Question about Garmin GPS
My Garmin GPSmap 76CSx will begin to start up, but as soon as you release the power button the screen fades away.
This problem can occur when the map file is corrupted or can't be read. Try putting your sd card in a reader and deleting the GMAPSUPP file (in the GARMIN folder) and fitting it back in your device. Then reload the map from Mapsource onto your handheld.
Posted on May 01, 2013
SOURCE: Garmin GPSmap 76 not acquiring satellites
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
Posted on Nov 24, 2008
  • 4 Answers
SOURCE: Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Posted on Jul 04, 2009
SOURCE: Garmin gpsmap 295 will not run from internal battery power
I had the same problem. Reluctantly, I removed the batteries and the 8 phillips screws from the the case back perimeter. Be careful on opening. The unit is designed to open from the top and hinge at he bottom to keep the ribbon cables from being stressed. The unit should open nicely and lie flat on the table with the two bottom halves butted against each other. Get a magnifier and ensure the printed circuit board attached to the bottom half has all 3 screws. (I found one missing that has 2 functions - securing the board and delivering battery power. Mine had wedged against a piece of clear plastic...it was hard to find!!!) I carefully removed the wedged screw and returned to the circuit board left most attach point. Close up the unit and we were back in GPS heaven. Battery power restored!!!! and my $250.00 still in my pocket. Yipppeee.
Posted on Jul 09, 2009
praky16
  • 744 Answers
SOURCE: My screen went black. Worked the night before.
hi..
when the unit is on try to press and hold the reset button for 10 seconds and then release if this will not work charge the unit for 3 to 4 hours using a wall adapter and if still not work try to check if there is a latest firmware update for the gps then download it.
thank u
rate me!!
Posted on Jul 15, 2009
  • 84 Answers
SOURCE: I tried turning on my
These units seem to be suffering from a bad connection on the inside of the unit. My wife's did the same thing. There was a connection inside that wasn't making contact. First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps. Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker. Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag. Let the unit sit over night. In the morning remove the tape.
Let me kinow if this helps.
Posted on Mar 11, 2010
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 07, 2011 | Garmin GPSMAP 76CSx GPS Receiver
I cant uploaud waypoints to gpsmap 76csx
Try reloading the software, then load the program, then attach the GPS.... Should start communicating at this point. Make sure the cable is seated correctly....
Feb 14, 2010 | Garmin GPSMAP 76CSx Handheld GPS GPS...
My Garmin GPSmap 76CSx was working just fine. After leaving it unused for a couple months with a pair of alkaline batteries installed, I tried to turn it on. It would not come on. I checked the battery...
Try connecting it to USB and powering it up, to confirm that unit still works overall. You probably damaged battery connectors. Check if you can clean the connectors better, otherwise you may need to do some soldering to fix them, by yourself or n a repair shop. Check with Garmin if they have suggestions: a leaking battery should not disable a GPS.
Dec 10, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
I have a Garmin 76CSx that freezes on start-up screen, no buttons have any effect. Only way to switch off is to pull batteries out.
I had the same thing. Seemed to be a faulty SANDISK 2GB MicroSD card. When I pulled it out, the unit worked again.
Sep 30, 2009 | Garmin GPSMAP 76CSx GPS Receiver
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Apr 22, 2009 | Garmin GPSMAP 76 GPS Receiver
76cs reset
Hold down ENTER and the PAGE buttons while powering up.
Jan 19, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Unable to pick up satelites
hi
problem with my garmin 76csx .. the reciever shut down.. cause by pushing power and other botton while search my navigator find..
no help from my service guys i bought it from they suggest i send it in for service..
solution went to upgrade webpage.. and downloaded a software for the chipset..
system came back on line looking for satellites..
yahoo.....
Jul 04, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
GPS Logo
280 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
