Question about Tefal ActiFry Deep Fryer
Paddle goes round but very slowly, and is not as noisy as normal?
    New Friend:
    Problem Solver:
  • 10 Answers
The fan is stuck . Take fan cover off at the back , and spin it with a screw driver , But please do it quickly if you have it set to on . or try it first with plug taken out. Hope it solves problem
Stevemaxwell@hotmail.co.uk
Posted on Feb 13, 2013
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
The gray plastic around the top of the pan and the paddle gets burnt on greese want an easy cleening solution
Soak the paddle and ring in very hot water with some washing up liquid and a dishwasher tablet. Leave it until the water goes cold, then rinse and wash as normal.
Feb 06, 2012 | Tefal ActiFry Deep Fryer
Brake paddle slowly goes down when brakes are applied
If your brakes system has no air in it...Your master cylinder or brake booster is bad.
Jul 18, 2011 | 1996 Honda Civic
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Having trouble getting the kneading paddle on the post. Does not seem to fit. Is ther anything special I need to do other than push it on?
one side of the post is kind of flat and the other side is round. You need to line up the flat side of the hole in your paddle with the flat side of the post and then it should slip right on. You know that old saying " you put a square peg in a round hole" that is kind of what is going on with your paddle and post ....the 2 flat sides of the paddle and post have to be aligned.
Jan 28, 2011 | Oster 5838 ExpressBake Bread Maker
Having trouble with the brakes on my '90 Ford ranger. Replaced the master cylinder and still have very little braking power. Any help would be appreciated!
***Seek out professional help this vehicle is not safe to operate.***
Check the vacuum line going to the brake booster.
This is the big round chamber behind the master cylinder.
Hope this tip helps.
R/
David
Jan 23, 2010 | 1990 Ford Ranger SuperCab
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
GSG22KEPAFBB FREEZER VERY NOISY
15 mins or more is normal. noise could be due to ice build up round the fan - worth checking. otherwise fan could be noisy just due to age and needs replacement
Jun 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Tefal ActiFry Deep Fryer Logo
234 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
