Question about Kenmore Dryers
11060702990 banging noise
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Could be a bad tub wheel the tub rides on ,hopefully not a pair of sneakers
Posted on Jan 16, 2013
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Dometic banging noise
Not real sure what could be banging and clanging as there aren't really any moving parts. There have been some reports of gurgling sounds coming from the cooling unit and also water pipes 'hammering' when the pump is on.
Mar 09, 2014 | Dometic RM2852 Refrigerator
Banging noise when you drive
This is a hard problem to describe, I know, and I will toss out a few possibilities. If the noise occurs when the car is accelerating, it can be motor mounts, or carriage mounts on front-wheel drive vehicles. Transmissions can bang into gear. Drive shaft u-joints can bang before they fail. C-V joints in front wheel or 4 wheel drive units can bang when worn out.
The exhaust system can break loose and bang on the frame. Brake calipers can rock in their mounts and transmit sound. Tie-rod ends can make a knocking noise on every bump you hit. There were recalls on gas tank straps for some Ford made units, so a loose gas tank can bang.
Dec 30, 2013 | Mercury Cars & Trucks
Banging noise
I'll need a lot more than banging noise to help you.
What is the make and model of the sewing machine. When did the banging start?
Oct 16, 2013 | Sewing Machines
I can't figure out the banging noise coming from center underneath dash When I drive it down the road, no noise until I turn from left to right. If I turn it left to right and apply brakes there is no...
big bang theory.
Ok, I've never heard of this happening to someone. If you turn left or right and apply brakes there is no noise. That means that the front end is probably ok. If it doesn't seem loose that way.
If you have a Sears nearby take it to them so they can listen to this banging.
They probably won't charge to look at it.
Jul 09, 2010 | 1996 Pontiac Grand Am
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
