Question about Canon i9900 InkJet Photo Printer
Support Code : 69 The printer is updating the firmware. Turn the printer off and then back on. If this message appears again, update the firmware once more. My Canon i9900 suddenly won't print, turn off or do anything. This is the message I receive. I was not installing any firmware nor even using the printer when the green light started flashing. Now continuously flashing orange. Any ideas? Thanks!
2 Suggested Answers
  • 883 Answers
SOURCE: "The printer is updating the firmware"
try removing power supply to printer for 15 minutes....same problem when re-powered? If so, then the firmware has been spammed and must be updated. Contact Canon tech support.
Posted on Jun 18, 2007
"system timeout" lexmark
The frimware update cannot see the printer because the printer is in error state. You need to clear the error by disregarding the error. To do this, you to make the error invalid. Please follow the steps below:
1. Turn off the printer.
2. Press and hold the the "back" and the "left" arrow button, and then turn the printer on.
3. When the printer displays "Invalid Engine Code", update the firmware of the printer.
Dec 05, 2012 | Lexmark X543dn Laser Color All-In-One...
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
I tried several times to install the new firmware update for my Lexmark Pro901. The update is not able to find the printer. I also try to connect it via searching for the printers IP adress. But it did not...
If you're getting an error message, "There's a problem with your printhead" you won't be able to update the firmware of your printer. You need to get rid of the error message first before applying the firmware update. Here's how:
  1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
  2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
  3. Once you have the printhead removed, close the cover of the printer.
  4. It will ask you to "Open Cover to Install the Printhead". Press the Home icon.
  5. It should take you back to the Main menu.
  6. Proceed with the firmware update. Just go to www.lexmarklabs.com/firmware and choose the model number of your printer.
  7. Once the firmware update is successful, go back to step 1 and install the printhead.
If it doesn't work, try to connect the USB cable. Or you can check out this link: http://bit.ly/mDKqh7
May 01, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Can't play mp4 error code 69-CooD119A
try updating your xbox, if you never connected it to the internet. there wasa a firmware update that made this compatible as of 2007. if that doesn't help, try converting the video to a different format.
Jan 12, 2011 | Microsoft Xbox 360 Console
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Only first print job is done. ( HP color laser jet 2025.)
Hey Sean,
Is the printer networked or connected through USB, it could be either a problem with the spooler or a problem with the formatter board, try the following:
Turn the printer off:
While the printer is off hold down the right arrow (next to the OK button) and the cancel or x button, turn the printer on while still holding and continue holding until you see the message permanent storage displayed on the lcd screen, let go of the buttons and wait for the printer to display the ready message again. This is known as a NVRAM and will reboot the printer, completely clearing out any corrupt data.
Print out a configuration report if your printer is networked through a router, and check to see if the ip address has changed from what is displayed in the ports tab under the driver properties.
Check the firmware date code; under product info on the configuration report. Check on the hp.com website under support & drivers for your operating system and the latest firmware update, if your printer is out of date, download the update and sync your printer
Try printing a test page (go to your printers folder, right click on the icon, go to printer properties, and go to the general tab) if the test page does not print, configure the ip address manually on the ports tab.
You can adjust the printer to print directly without spooling under the advanced tab, select the option to print directly to the printer.
If this does not fix the issue the it is definitely the formatter board and you will have to have the printer service or call hp if within the 1 year warranty period and ask for an express exchange (US Only) , where they will send you a refurbished model for a fee typically $69 + tax.
Let me know if this solves your issue
Al
eliteprintersolutions@gmail.com
Jul 07, 2010 | HP Laserjet Cp2025n Printer
Intermittent doc feeder jam. rollers are cleaned and paper path is clear. doc feeder noisy
This could be happening if the the firmware is out of date, check the hp website under support and drivers. After you have input the product number cb534a, select your operating system and you will see the firmware update utility. Before running the updater make sure that the phoneline is disconnected, and print our a configuration report from the printer check the firmware date code under product information. If the firmware is up to date do not update, try an nvram:
hold down the down arrow and the cancel button while the printer is off and reboot, hold the buttons down until you see the permanent storage message displayed.
If this does not solve the issue it could be a hardware failure, if within the 1 year warranty period, call hp and have them refer you to a local asp or opt out for the express exchange, it incurrs a cost of $69, but you will get a refurbished printer as well as a shipping label to send your deffective printer. Hp's tech support number is 1800 334 5144.
Al
Jun 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Lexmark t642
I too ran into this problem. Printer is about 2-1/2 yrs old.
Using it as a network device. I updated firmware from
a Mac OS X computer on the network.
a. Uploaded the firmware by going to lexmark site.
Do this first in preparation of upgrading firmware.
Follow instructions to get firmware update.
b. power cycle the printer (turn off & unplug power from unit)
c. power printer and turn switch back ON.
happily printer stays alive long enough to upload the new
firmware update.
d. Log on to your printer via a computer on your network
Open a browser, address will be your printer's IP address
or dns name. ex: http://192.168.1.3 (note: if you password
protected the account, you will need that info)
e. Follow menu to Configure -> Update Code where you will
"browse" to the file on your local computer (ex:
LSSTN234.FLX) and then hit the FLASH button
Dec 12, 2007 | Lexmark T642 Laser Printer
49.4C02 Service Error
The 49.4C02 error usually follows a paper jam. When the user closes a door after clearing the jammed media from one area of the printer, the control panel immediately posts a 49.4C02 error. Often, the customer will then power cycle the printer and it will hang at Checking Printer. For the 49 error to occur, additional media must still be stuck in the paper path.
Firmware version 5.005.3 contains a fix that allows the printer to recover and notify the customer of the location of the additional jammed media in the paper path. Customers who experience this issue should update to the newer firmware
Oct 15, 2007 | HP LaserJet 2420 Printer
Canon i9900 InkJet Photo Printer Logo
67 people viewed this question
old marine
old marine
