Question about Dell Inspiron 1545 Black Intel Celeron 900 22GHz 2GB DDR2 RAM 250GB 5400RPM Hard Drive DVDRW Windo (609722305754) PC Notebook
Dell Inspiron Black Screen
My Inspiron 1545 began by having a red line through the middle of the screen. Now the screen in blank-always, nothing ever appears. A LCD replacement was attempted and the screen was still blank. Additionally, an external monitor can be hooked up and displays perfectly. Is this a graphic card problem?
  • 691 Answers
More likely a fault with the wiring or an invertor board problem
Posted on Jan 14, 2013
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
  • 4 Answers
SOURCE: Dell Inspiron 1000 laptop LCD screen blackout
I HAVE POSTED THE SOLUTION FOR THIS BEFORE. ON THE LEFT REAR THE SCREW FROM BOTTOM OF UNIT TO THE LCD. LOOK INSIDE WHERE THE TOP AND BOTTOM GO TOGETHER YOU WILL SEE A PIECE OF ALUMINUM TAPE IF IT STICKS OUT PAST THE BOSS TOWARD THE PC BOARD. WHEN YOU MOVE LCD THERE IS ENOUGH FLEX FOR IT TO SHORT TO PC BOARD. TRIM THIS OFF AND YOUR PROBLEMS WILL BE SOLVED. CAUTION REMOVE BATTERY AND UNPLUG FROM AC BEFORE THE ABOVE. BOBBY
Posted on Jan 09, 2009
patemi
  • 366 Answers
SOURCE: Dell Latitude D600 - Screen goes blank while booting
Check you config against this tutorial
Posted on Jan 12, 2009
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 21, 2009
  • 5 Answers
SOURCE: Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Posted on Dec 16, 2009
I have dell 1545 inspiron laptop. One day suddenly, the laptop's lcd screen shows colored vertical lines. I connected laptop to lcd tv and I could see desktop. I tried to enquire at various shops and
your LCD it toast its better to get it fixed. the cable only by-pass your lap top LCD thus allowint you to use your pc via another monitor sourse
Sep 27, 2014 | Dell Inspiron 15 1545 Notebook
RIGHT HALF OF DISPLAY APPERS WITH VERTICAL LINES
Go to this link http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=DSN_361151&isLegacy=true
When you get there scroll down and follow the instructions. That should solve your problem if your video card is not damaged.
Aug 14, 2011 | Dell Inspiron 1545 Notebook
I have a insprion 1545 that half of the screen is white with vertical lines on a white back ground. The other half is fine but can only view the left half of the screen. I hooked it to an external monitor...
It is a screen problem. You have to replace the LCD. It is either cracked or the electronics of the LCD is faulty. Find the part number on the back of the LCD and look for it on ebay.
Aug 08, 2010 | Dell Inspiron 1545 Notebook
Blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Apr 25, 2010 | Dell Inspiron 1545 Notebook
Only till recovery page then boom-blank
Try attaching the external monitor to VGA port to see if you get the same problem and then post back.
Mar 04, 2010 | Sharp 12.1 in. XGA TFT Active Matrix...
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Nov 30, 2009 | Dell Inspiron 1545 Notebook
Red line on TV screen.
The LCD panel is defective...sorry I have to give you bad news.
May 13, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Dell Inspiron 1545 Black Intel Celeron 900 22GHz 2GB DDR2 RAM 250GB 5400RPM Hard Drive DVDRW Windo (609722305754) PC Notebook Logo
123 people viewed this question
Alun Cox
