Question about Whirlpool Refrigerators
The food on the top shelf freezes
Whatever I put on the top shelf freezes. and its on factory setting. model number gsc25c5eyy00
  • 35 Answers
SOURCE: Food freezing in some parts of refrgerator
this problem has to do with airflow.make sure that all vents are free.
Posted on Jun 25, 2007
  • 11 Answers
SOURCE: refridgerator problem
Low refrigerant level is a common cause to this problem. Try a lower setting and if that doesn't work, you'll have to call the repairman :( Best regards, Denis
Posted on Oct 09, 2007
peyton32034
  • 410 Answers
SOURCE: Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Posted on Dec 16, 2007
aborcass
  • 2651 Answers
SOURCE: Amana TempAssure
heres a link to your owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/12642722.PDF
Posted on Apr 19, 2008
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
Food on top shelf is freezing
Not sure what model you have so I need to guess that it only has a thermostat control that regulates temperature? Can you post the Model Number? If your model only uses the temperature control to regulate temperatures then I suspect that the temperature control is at fault and needs replaced. Spare parts HERE Can you locate your model number? Click HERE I am here should you need me, Thanks John TrippAppliance 911
Contact Me Here
Mar 12, 2014 | Hotpoint-Ariston Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Jan 28, 2011 | Amana ARB190RCB Bottom Freezer...
My fresh food on the top shelf is frosting up. i had a problem when i had to turn the freezer down this winter. now in the fresh food section. top shelf the food is starting to kinda freeze. once there was...
Gee I don't know what brand you have so I gotta shoot from the hip. As you know the freezer is where the cold air for the fresh food compartment originates. What you have is some sort of control problem. I suspect it is a sensor. These sensors change in resistance as the temperature changes. A lot of folk waste money buying new controls when all they needed to do was replace the sensors. I have a few manuals in my stash that are for bottom mounts and a french door manual. You may want to look through these to get an idea where these sensors are located.
Late model GE
Kitchenaid
LG
GE Bottom mount
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 15, 2010 | Refrigerators
I have a side by side Fridge. Model TPX24PRBBWW
turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Nov 15, 2009 | Refrigerators
Food is freezing on our top refrigerator shelves
well i'm not exactly sure what fridge you have but that is usually caused by the what they call a baffle...which is a flap that opens and closes to let the cold air from the freezer to the fresh food side. It sounds as if the baffle is stuck open or moving way too slowly and thus freezing your fresh food. You can find a part number and price at partsselect.com all you need is your model number. Good luck!!
Oct 03, 2009 | Refrigerators
Ed22pwxxn00 setting on 3 top shelf items freeze. Is our 18 yr old fridge going out?
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Aug 29, 2009 | Whirlpool Refrigerators
Fridge is freezing food on upper shelves
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Sep 05, 2017 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
