Question about managemylife.com
My problem is :refrigerator is hot outside, what can i do?
I got the new refrigerator ,but it is hot outside when it is working.can you tell me what i do?
    Problem Solver:
  • 7 Answers
Unplug for five or ten minutes and do this. Take off the back cardboard protector and vacuum out the dust on the coils and especially the fan being careful not to bend the fan blades. Hardware stores also sell a bush for the coils. It can reach in places the dirt needs to be broken loose. Once you clean the dirt off it will run cooler. Caution, The fan blades are usually thin aluminum. Just be aware they bend easy and can be bent back into shape.
Posted on Jan 14, 2013
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
My dd lg refrigerator model GGL-478YSX4/2011 BEEPS EVEN WHEN DOORS PROPERLY CLOSED
Its telling u that the refrigerator setting should be lowered or raised. I keep the freezer setting on the highlighted setting and depending on the weather your refrigerator will beep when the setting is either to high or to low. If its hot and humid outside it probably raise one notch and if the outside temp has cooled then lower one notch. Just have to experiment. Good luck
Jun 12, 2015 | LG Refrigerators
My fridge is working but to touch the outside it is extremely hot to the touch. What would be wrong with it?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 07, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The outside of the refrigerator is hot. It is 4 - 5 yrs old.
heatman101
Jul 28, 2011 | Kenmore Side by Side Refrigerator
Mullion on ge monogram extremely hot and freezer is working fine and refrigerator appears to be ok. Have vacuumed the upper and lower sections and turned the energy saver switch on. Where to get manual and...
It's not abnormal for the condenser to get hot especially in the hot and humid weather we've been having. Usually atleast some of the condenser coils are welded to the inside of the sides of refrigerators and freezers. Depending on how hard the unit has to work to keep it's inside cold the outside gets hotter.
I hope this helps.
Jun 30, 2010 | Refrigerators
Refrigerator gets hot on left outside
There are a couple of things that could cuase this and neither are anything to worry about.
One cause could be a heat strip to keep the outside of the refrigerator from sweating.
The other is the the condenser coils sometimes are run up the side of the unit to cool the freon and disipate heat.
As long as everything else is working properly I would not be concerned about the warmth. It is "normal".
Hopefully this will help you solve your question.
Thanks for using Fixya!!
Heatman101
Nov 23, 2009 | Refrigerators
Kenmore Refrigerator all outside body too hot.
I would say your compressor is running constantly and it is the heat from this that is making the fridge sides and front hot.
If it is that would indicate you have problems with either
1/ Your refrigarant is undercharged
or 2/ Your thermostat is defective
A stand alone refridgerator / freezer would tell you if it is keeping the correct temperature. If it is than a freon undercharge would be indicated.
May 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana Top Freezer Refrigerator is hot to the touch on the outside on the sides by the freezer. Still working fine inside. Is something getting ready to break inside?
The problem was the fan. It was hitting the metal enclosure and had stopped working. We made an adjustment and cleaned it and now it works fine and the hot spots are gone.
May 04, 2009 | Refrigerators
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
