Question about JVC HD-70G886 70" Rear Projection HDTV
Vertical lines I have a JVC HD-70G886. Today when I was watching it vertical lines appeared in about 5 areas across the screen. I checked input sources and it was the same for all. I had replaced the lamp about 2 months ago and it has worked great until this. I unplugged it and let it cool for a couple hours. When I turned in back on the same lines showed up about 15 seconds after I turned it and seemed to get worse. Is it a power supply problem? Any suggestions?
  • igobigfly Dec 12, 2007
    I have the exact same issue. TV guy told me today that it's the light engine but I'm doubting that prognosis now.
  • Anonymous Nov 28, 2008
    I have a JVC HD-70G886. Today when I was watching it vertical lines appeared in about 5 areas across the screen. I checked input sources and it was the same for all. I had replaced the lamp about 2 months ago and it has worked great until this. I unplugged it and let it cool for a couple hours. When I turned in back on the same lines showed up about 15 seconds after I turned it and seemed to get worse. Is it a power supply problem? Any suggestions? My email is billy_burden@bellsouth.net.
  • 41 Answers
Get some freeze spray from radio shack then try placing a little spray on each chip on the video board and power supply board and each time you spray a chip look for the picture to clear up. When the lines go away you have located the bad IC.
Posted on Jul 22, 2007
Green and Red (thin lines) across entire screen [JVC 70 G886 HD TV]. Screen went to all green (wide and thin) within 1/2 hour and picture hasn't come back. "Input selection" box is visible and clear...
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Apr 22, 2014 | JVC HD-70G886 70" Rear Projection HDTV
4 thick black vertical lines showed up on my hd-70g886 today. any cheap suggestions? or should I throw it away?
That is a defective Digital Light Processor. It is part of the Light Engine Assembly. I definitely recommend NOT repairing it. Average cost to replace is around $650.00 if still available. Mfg's want DLP sets off the market for to many problems.
Nov 30, 2010 | JVC HD-52G886 52" Rear Projection HDTV
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Vertical lines appear on the screen.
It appears like there is a bad capacitor in the horizontal circuit. Try to put a fan near the ventilation trap, just for a test.
the part cost almost nothing but having someone to your house is expensive.
Your decision.
Jul 01, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Westinghouse 32" LCD - Vertical Line across top of picture
i had this same problem, it ended up being a loose connection on mine, attached picture is where the connection was loose, i took off the back panel and just reattached it, and it was good as new.e87b8ee.jpg
Nov 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
JVC HD-70G886 70" Rear Projection HDTV Logo
178 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
