Question about Dishwashers
Any ideas how to solve this dishwasher from leaking.
  • 691 Answers
Clean the door seal. any residue on it could cause it to leak. check the hinges are'nt loose in anyway and te catch hold it fully closed. It may need new door seal
Posted on Jan 14, 2013
Leaking Milano Dishwasher
check all screws in door,and seals,also you might have a disconnected rinse hose in the door
May 13, 2015 | Dishwashers
My dishwasher leaks from the bottom of the door. Any ideas as to why.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 25, 2011 | Bosch 24 in. SGS43C12 Classixx...
Leak from door seal - how to solve?
Leaking Dishwasher
heatman101
Jan 06, 2011 | Candy DFI Plan Built-In Dishwasher
HOTPOINT AQUARIUS DISHWASHER...FRONT LEAK
Leaking Dishwasher
heatman101
870943q45
Jun 15, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Leaking dishwasher
Leaking Dishwasher
heatman101
hafhgf
May 16, 2010 | Asko 1385 Dishwasher
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
Dishwasher leaking on floor
Leaking Dishwasher
heatman101
wata
Feb 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Diswasher leaks
Leaking Dishwasher
heatman101
dhfgs
Jul 06, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
