Question about Exercise & Fitness
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
I have had the lid off it, and there are 2 lights on the mcb that are not lighting up, a programme starts then no speed, then it goes on to display the LS message. the lights which dont light up are the bulb next to the 'limit' writing, and the bulb above where it says tourqe on the mcb. any ideas please??
    Top Expert:
  • 12,223 Answers
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
God bless youi have a herritage t101, it displays the Ls error  - 1_14_2013_9_25_21_pm.png
Posted on Jan 14, 2013
3 Suggested Answers
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
SOURCE: ls error
Showing l5 or ls on sceen of my york t101 treadmill please help me out thanks.
Posted on Jun 29, 2011
2004 Lincoln ls brakes won't stop sweakin
Take them apart once a year & clean off all rust & service them
properly,& you won't have any issues
If a professional works on them, they go back together
with all the rust & no lube whatsoever & you have squeeking.
Any brake issues are due to neglect & improper work
I have never has one problem in 49 years of driving
WHY -- because I do all my own work
I have a 2004 LS V8
Sep 25, 2011 | Lincoln LS Cars & Trucks
What does LS on the display and dont end the cycle?
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
MY WHIRLPOOL WASHER WILL NOT WORK STATUS WASH CODE LS
lid switch error,thecontrolshould flash this error code if it cannot detect the lid switch opening and closing properly.this error code may also be used if there is a disagreement between the motor and machine controllers on the stat of the lid switch.the control should not allow the unit to run in this condition.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
York t101 treadmill ls error
May 11, 2009 | York Exercise & Fitness
Ls error
May 09, 2009 | Exercise & Fitness
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
WASHER CODE
You have a lid switch problem.
check for junk plugging up the area of the lid switch.
It needs to move both to the contact position(when door is closed)and to the non contact position(when door is open).
Also, the switch may be bad, or the wires going to it may have been cut by the drum because sometimes these wires are not fastened good enough and are able to contact the drum.
Anyway, the switch is just like turning a wall light switch on and off.
There may be an actuator on the door that presses against the switch, that could be missing(fallen off/broken off).
Feb 12, 2008 | Washing Machines
Lid Error
Most systems either have a photo interrupter or a switch on the top to let the copier know its closed. Since you had it moved most likely they knocked it out of its position.Or broke the tab or plunger off.
Oct 17, 2007 | Konica Minolta DiALTA Di200 Copier
Exercise & Fitness Logo
131 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
