Question about Kenmore Washing Machines
How to remove timer switch from Kenmore model 110.26912691
How to replace timer
I have a link to Sears parts direct. According to the diagram, there are screws in the back of the top panel. Remove the screws (1) and you can take the back cover off (4). Then remove the wires from the timer (13)that are plugged into it, and the agitation delay board (19). Then remove the knob and nut holding the timer in place. Pull out the timer and then do the reverse procedure. Here is the link to the diagram. http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11029832801/0582/0153200/K0905012/00002?blt=06&prst=0&shdMod=11029832801
May 13, 2014 | Televison & Video
Where is the control panel on a Kenmore 70 Series with Model 110 24722300 washing machine
You remove some screws on older models. Newer models simply have spring clips.
Your washer (I looked it up on sears parts) has a timer.
That timer has a knob that screws off and then you remove the dial indication escutcheon and the mounting screws can then be removed to swap out that timer.
This is the connection to the lid switch. You gotta unplug that to
remove the case so you can get to the inner components.
The connection has a green ground wire and 2 wires that go off
to the lidswitch. If the lid is shut and you cannot get an ohms reading
between them 2 then the lidswitch is bad.
With the case off you can start the washer and put it on spin mode and figure out if you have 120 volts to this connection for that lid switch. Placing a jumper between the 2 hot wires will allow you to wash or spin with the case off to hunt for noises and leaks while the machine is in operation.
I have a few pages I compiled on this direct drive washer with more videos and photos, service manual added.
How it works: direct drive washer
Top loading Kenmore notes
Feb 07, 2011 | Kenmore 15864/15862 Top Load Washer
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
Removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Washer wont progress through the cycles, suspect timer.
I was able to fix the problem by replacing the timer ($106 CDN). Thanks for everything.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Washing Machines Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
