Question about Garden
Motor races and will not feed - Garden
    Sergeant:
  • 322 Answers
If the RPM's are abnormally high you have a lean fuel mixture which will cause great internal damage. A lean condition is caused by an incorrect high speed needle adjustment on the carburetor or an air leak somewhere.
Posted on Jan 16, 2013
My sewing machine shark euro-pro 361 is jammed. Needle will not move. What do I do
See if you can remove the bobbin from the machine. Most likely the bobbin and upper threads are entangled and have trapped the needle. You can remove the presser foot and loosen the needle from the needle bar (as though you are going to remove it). Then if you get a small pair of scissors in there and start nipping thread pieces and removing them with tweezers, you may be able to loosen it up.
Jan 16, 2017 | Euro-Pro Sewing Machines
2004,Mazda 6,4cyl,battery gets really hot,and now automatic transmission will not shift stays in 3rd, replaced battery, and is still doing same thing
SOUNDS LIKE ONE PROBLEM CAUSING 2.BRAKE FEEL MUSHY? FROZEN CALIPERS HOLDING BACK TRANS-RACING MOTOR CAUSING OVERHEATING BATTERY? OR.... BAD TRANS CAUSES RACING MOTOR TO OVERHEAT BATTERY.? SOUNDS LIKE 1-(CAUSE) SLIPPING TRANS , RACING ENGINE,,BATT OVERHEATS ETC........DEPENDS ON WHICH STARTS FIRST-TRANS ISSUE, 2 ENGINE RACING, 3 HOT BATTERY? THAT EQUALS A PUZZLE READY TO BE SOLVED. IF YOUR BRAKE SYSTEM WHERE IN GOOD SHAPE (EMERG BK TOO) I WOULD LEAN TOWARD THE TRANS FROM HERE. GOOD LUCK, FRANK M (PS, DONT KEEP CHANGING YOUR BATT BECAUSE OF THIS,THE ALTERNATOR IS OVERCHARGING THE BATT DUE TO THE RACING OF THE ENGINE DUE TO EVERYTHING ELSE. GO FOR THE CORE!
Feb 14, 2016 | Cars & Trucks
I lost instructions for imaginarium motorized marble race
Any luck finding instructions for I need instructions for imaginarium motorized marble race. The one above is for the deluxe marble race not the motorized.
Jun 09, 2012 | Toys
Throttle seems stuck on a 1995 ford probe as when engine is started it races with no control
This sounds like a major vaccum leak or a stuck IAC(idle air control) motor.Look for a loose/broken vacuum line(a large hose feeds the brake booster and the PCV valve).(my stepson's Sable had a rotten vacuum elbow).
May 04, 2012 | 1995 Ford Probe
Motor races when you step on drakes
check all vaccum lines first when you step on the brake pedal does it feel normal. sounds like when your steping on the brake it causes a vaccum leak on the motor and causes it to race
Oct 18, 2009 | 2005 Ford Taurus
Material won't feed just stays in one place, the drop feed control doesn't move the teeth.
hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Apr 19, 2009 | Singer Sewing Machines
Putting the race back into the machine
The race thing as you call it does not look broken compared to mine. I don't see that you can put it back in wrong there should only be one way it would fit. The point goes to the back under the feed dogs.
Jan 31, 2009 | Brother XL-6562 Mechanical Sewing Machine
My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Feb 26, 2007 | Brother LS-2125 Mechanical Sewing Machine
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
