Question about HP LaserJet 4650n Printer
Toner on transfer belt of an hp 4650n
The printer is pretty old but most of the parts in it are new but now it is starting to collect toner on the transfer belt. We don't want to have to buy a new belt system so we are looking for other solutions.
    Champion:
  • HP Expert
  • 312 Answers
Toner on the belt is normal unless it is interfering with the print quality. The belt cost around 300.00
Posted on Jan 31, 2015
  • 38 Answers
SOURCE: HP 4700 - tones dropping in on transfer kit w/ new toners
how old is it?
Posted on Oct 30, 2007
printech
  • 159 Answers
SOURCE: HP 4100 Toner out
please tray to reset printer cold reset turn the printer off then press the go button then turn the printer on stay press go button when the message on control panel appear cold reset
Posted on Mar 19, 2008
seeker5211
  • 1089 Answers
SOURCE: Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Posted on Feb 06, 2010
seeker5211
  • 1089 Answers
SOURCE: I have a HP 4650N Printer with an error code of
Known problem...upgrade the firmware
Posted on May 27, 2010
broyyce
  • 30 Answers
SOURCE: I have a HP laserjet
The problem is most likely with your fuser which is located in the rear of the printer. You may want to remove the fuser to inspect it for visible damage to determine whether it need to be replaced or not. broyyce.pngWhile looking at the back of the printer, pull the rear output door open. Push the door down to disengage the rear door stops (1). You will need a phillips head screwdriver to remove the two screws on each side of the rear cover. Lift the bottom of the cover first to disengage the alignment tabs at the top of the back cover, and then lift the cover away from the printer.
Remove the duplexer inlet guide by releasing two tabs (1) on the guide, and then sliding
the guide toward the back of the printer.
Disconnect two cables at the right, inside, of the device (callout 2), and then disconnect the fuser
power cable at the left side of the device (callout 3).
Remove three self-tapping screws (callout 4) and one grounding screw (callout 5).
Tilt the fuser slightly toward the back of the device, and then slide the fuser out of the back of the
device. Look at the two rollers inside the fuser and turn the gear on the side as you look at it. There may be something stuck inside the printer that is causing it to malfunction. If you see and damage on the fuser you can buy a new one from http://www.lbrty.com/
Good luck and I hope this helps!
Posted on May 19, 2011
How do I clean an HP 4650n printer
Can you be a little more specfic about what you want to clean. Outside? Inside? Do not use a regular vacuum to clean up spilled toner as it is so fine it will go right through the vacuum into the air and you will breath it in.
Aug 31, 2014 | HP LaserJet 4650n Printer
Printing Quality on HP 4550 Colorlaserjet
most likely the OPC (drum) or sometimes called "image drum or transfer belt located in the top draw. this is a consumable that needs replacing after it's life cycle is over. sometimes it will go below or over the life cycle, it all depends on many variables.
I would take out all the consumables, toner, belt and so on and use a dry cloth and small vacuum to clean the inside of the printer, then test it again, but when you have streaks it is usually the transfer belt. other possibilities is the scanner/laser window inside, sometimes it gets toner on the glass.
but step 1 is the Transfer Belt/Drum
hope this helps
Jan 14, 2008 | Office Equipment & Supplies
2600 empty waste bin
Waste toner on this model collects in the catridges and the transfer belt, there is no separate waste toner bottle.
Apr 18, 2014 | HP Color LaserJet 2600n Printer
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
HP LaserJet 4650n Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
