Question about Husqvarna 450 e-series 18" Chain Saw
My 450 Husky has a leak from the oil tank at the bottom of the saw. Is there an oil plug at the bottom of the tank that come loose or unscrewed??????
If same as mine there is a screw under side to stop oil flow altogether for storage or to slow down if excessive flow but remember to open if using so the chain doesn`t burn out to soon
Posted on Jan 14, 2013
4 Suggested Answers
B-Roosky
  • 59 Answers
SOURCE: Oil is leaking out the bottom of the saw after
check the hose that goes to the oilway if everything checks clear you may have a crack in your oil tank due to excessive vibration and weak molding.
Posted on Jan 12, 2010
Testimonial: "Your answer seems about right. I'll look into it further and report back"
  • 4088 Answers
SOURCE: i have a 2005 Husky 137 saw that the bar oil tank
It will be necessary to replace the entire plastic casting containing both tanks. Repair of plastic cracks is not practical due to inability of any form of cement/glue to bond with the plastic and saw vibration would hasten the process. Just empty the tank out when not using the saw. Good luck!
Posted on Nov 19, 2010
  • 136 Answers
SOURCE: husqvarna rancher, leaks oil when saw is off.
The hose is leaking. You will have to replace the hose. You do not have to disassemble the saw in half as many seem to think. Just some of the parts that are in the way. You can insert a wire and pull the hose out from the oil tank along with the filter. It goes in and you remove only the parts that are in the way where the hose comes out.
Posted on Nov 20, 2011
My oil reservoir is leaking
The grey plug in the base of the oil tank is the oil filter it will twist 1/4 turn and pull out, to replace push back in and turn 1/4 turn there is a leg on it that locks into the orange tank, there is a screw driver slot in it to assist this, they can be really tight try not to force too much or you will break it.
Jan 14, 2013 | Husqvarna 450 e-series 18" Chain Saw
Husky model 36, 16 in. bar, over oiling, non adjustable pump, will pump out a full tank of oil on about 3/4 tank of fuel, everything is spotless and dont have a clue on how to fix it.
The biggest problem with oiling on this machine was always under oiling, the pump is a fixed capacity so it should be impossible to over oil, it is more likley leaking from around the oil pump pick up and delivery hoses, or from the oil tank breather.If all is ok there then it is going to be a replacment pump.
May 11, 2011 | Husqvarna Operator's Manual 365 372xp ...
I have a 2005 Husky 137 saw that the bar oil tank leaks (drains out) when not using, can i fix it? or live with it.
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
How do i adjust the bar oil
turn the saw upside down, there is a little screw that only turns a quarterturn, turn it counterclockwise for the maximum flow
Nov 25, 2009 | Husqvarna 450 e-series 18" Chain Saw
When I top up the chain oil it runs out of the opposite side really rapidly, I don't see how to fill it in the instruction booklet
Are you using bar oil? Is it less than 2 years old (warranted)? Did the chain come off and hit the tank?
I think your saw may have been impacted and the oil tank is broken. I didn't see an oil vent on the IPL but if the filler is on the bottom of the saw and you must lay it on its side to fill there must be one. Take it and your bar oil with you and stop by your friendly neighborhood Husky dealer. Ask what they think the problem might be. You might be pleasantly surprised. Purchase some 2 cycle oil, a new chain, some bar oil, something. When time for a new saw remember how they treated you.
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Oct 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
Chainsaw leaks chain oil when not in use
You might try loosing the oil cap on the chain oiler filler cap to release any preasure that might have built up during use and is forcing oil out as it sits. It sounds like a simple fix but it might just work.
May 06, 2009 | Garden
Husky 61 leaks chain oil? Gasket on tank???
HI. TO FIX WHAT YOU ARE TALKING ABOUT, YOU HAVE TO STRIP THE SAW AND SPLIT IT IN HALF. NOW I HAD THAT PROBLEM ONE TIME AND I FOUND WHERE THE LEAK WAS CLEANED IT VERY GOOD AND PUT SOME JB WELD ON IT AND AS FAR AS I KNOW THE SAW IS STILL GOING. GOOD LUCK. JIMBO
Feb 27, 2009 | Garden
Husqvarna 450 e-series 18" Chain Saw Logo
110 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
