Question about Maytag Neptune MAH5500B Front Load Washer
Was the Maytag MAH300AWW recalled
I have a older Maytag washer MAH300AWW and have had problems with it since the initial purchase. Once again I need it repaired and was checking online for information on the washer. I found that many models were recalled. Has this model been recalled.
  • 159 Answers
SOURCE: Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Posted on Jul 12, 2007
  • 3 Answers
SOURCE: maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Posted on Jan 11, 2008
  • 50 Answers
SOURCE: maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Posted on Jul 18, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
  • 62 Answers
SOURCE: need manuel for maytag stacked washer/dryer unit model lsg7806aae
go to this link and download the manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSE7806A&siteCd=MT_EN_US
Posted on Sep 02, 2009
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Jan 25, 2010 | Maytag Washing Machines
I have a Maytag Neptune 1st Generation and the washer door gasket always molds, how to clean and how to prevent molding
The Maytag MAH300AWW was the first generation front load washer. Your MAH5500BWW is a much newer version and has a boot drain and door venting to minimize the mold. Just be sure your drain (bottom center of the boot) is clear. Use a solution of 1/2 cup of Granular Dishwashing Detergant and 1 cup of Chlorine Bleach added directly into the tub. Run the machine through a hot was cycle (with NO clothes inside) every few months and this will reduce or eliminate the mold.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Need instructions for motor conversion kit for maytag neptune mah300aww
they come within the package when you recieve the conversion kit
.. if not contact where ever you purchased it and have them get to you
Apr 02, 2008 | Washing Machines
High speed spin problem
contact maytag at 1-800-688-9900 and ask whats going on and you need your machine fixed while it is under warranty, it is only covered for a year.
they may refer you to a whirlpool number but whirlpool now ownes matag so this is ok
Jan 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
76 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
