Question about Toshiba Computers & Internet
Since 2 months ago, my Toshiba Equium A200 suddenly freezes when AC power is plugged-in. When the laptop is in battery mode (meaning the AC power is unplugged), the laptop works fine and there are no problems within it. However, as Engineering student, I can't just work for few hours and recharge again the battery. I always work with my laptop for more than 3 straight hours. The lifespan of my battery is only 1 - 1.5 hours. To be more precise, sometimes my laptop won't boot at all when connected to an AC power. So what I did is to put the laptop in battery mode first and when it reached windows, I then connect the AC power. However, after few seconds, the laptop freezes and I cannot move the mouse anymore and I'll end up unsafely turning off my laptop.
SOURCE: Problem with battery on Acer Travelmate 4060
There are probably some corrupt files on the harddrive or there is damage on the hard drive. I would suggest to try using the windows setup cd or sony recovery cd to restore the system back to normal, if the problem is not solved by that then you most likely have a hardware problem which is most likely in the harddrive, might have to replace it, they don't cost much.
if you press f8 in start up to get the advanced startup menu, select safe mode.
start in safe mode and login
then
press start -> now run -> type in Cmd -> Type in the shell window -> chkdsk /F /X /R C:
if asked select Y to perform the operation on next start up.
see if the problem is solved.
Posted on Nov 15, 2008
HEMPYODA
  • 168 Answers
SOURCE: Laptop Battery won't charge
One thing you can check is the battery contacts on the laptop. You'll notice small metal contact points where you install the battery. clean those and make sure they are 100% dust free. IF there is any kind of dust build up or corrosion on the contact points they will not work correctly.
Also check for any physical damage to the contacts.
Please rate as "very helpful" if this helps your situation & i'd love feedback. ^_^
Posted on Sep 21, 2009
  • 232 Answers
SOURCE: touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Posted on Sep 30, 2009
    RescueTechLA
    • 2653 Answers
    SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
    Try removing / swapping / reseating the memory.
    Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
    Let me know what happens.
    Posted on Apr 04, 2010
    Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
    SOURCE: Toshiba Satellite L300 shuts down when ac power plugged in
    How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
    Posted on Jul 04, 2010
    Where can I find manual for Toshiba Equium A200-15i?
    Toshiba has the user manual as a zipped pdf in their archives. http://www.toshiba.co.uk/innovation/download_manuals.jsp?service=UK (use the drop down menus to select Archived files, Equium notebook, series A, A200). The direct link to the A200 PSAE0 is here: http://support1.toshiba-tro.de/tedd-files2/0/userman-en-20071025135106.zip . You will need to extract the file from the archive and then open it with Adobe Reader or a similar program.
    I hope this helps.
    May 20, 2014 | Computers & Internet
    Laptop Won't satrt if AC adapter plugged in. Works fine on battery
    Hi, Try to Upgrade BIOS.
    This will work same problem i had with my HP Notebook....
    My laptop was also working good without AC adapter and no response on Charging connection.
    Apr 26, 2013 | Toshiba Equium A200-1vo 15.4" 1.4 Ghz...
    Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
    Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
    Jan 10, 2013 | Computers & Internet
    My Toshiba Equium A200-196 will not switch on - power light is on and it's plugged into mains but pressing the on/off switch, nothing happens!
    hello
    try this: remove your battery and plug directly to the main power w/out battery. second remove thebattery press and hold the power button for ten seconds and put the battery back and power on your laptop.
    thank you
    Mar 11, 2011 | Toshiba Computers & Internet
    Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
    Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
    Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
    Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
    My Laptop Will not sleep on AC Charge
    Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
    May 23, 2009 | Toshiba Satellite A60-S1561 Notebook
    Toshiba Satellite A200 -AH9 Wont Turn On.
    maybe you have power conection problem
    your problem maybe on the circuit after the battery
    so you must check your circuit
    or you can contact your Laptop manufucturers
    Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
    Computers & Internet Logo
    108 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
