Question about Boxing
VECTRA C GEARBOX CODE GJ53 YCK
BROKEN
Spanner showing on dash when engine running vauxhall vectra c
VECTRA CAR WITH SPANNER WARNING LIGHT This Vauxhall Vectra car with spanner warning light illuminates or flashes yellow. Light will illuminate for around 3 seconds when the ignition is switched on. If the fault light illuminates whilst the engine is running, this signifies a fault within the engine or gearbox electronics system. The system will switch to emergency mode where fuel consumption may increase and the vehicles drivability reduced. A Vauxhall workshop must be consulted. If the light flashes whilst the engine is running, this signifies a fault within the electronic immobiliser system and the engine will not be able to be restarted.
Oct 25, 2015 | Vauxhall Cars & Trucks
Vauxhall vectra problems
check the pivot pin for the gear lever at the turret at the top of the box. you can check the shift rail operation her if you take the turret section and gear lever of the top of the box.
Jan 03, 2014 | Cars & Trucks
Gear box oil type, vectra 2003?
no engine size. ep80 oil. any brand
Jul 30, 2012 | 2003 Vauxhall Vectra
My 1999 1.8 petrol vectra is making a whirring noise in the engine when its steady in 5th it stops
very difficult to advise without heariing the noise ,opel vectra (vauxhall) nice motors these ,if noise stops in 5th then it could be the gearbox like the layshaft needle bearings caused by low or no oil in the gearbox ,remember 5th gear doesnt use the layshaft its on the end of the mainshaft behind the cover next to the wheel arch
Jun 04, 2010 | 1999 Volkswagen Passat
Hi, I have a 2000 holden vectra 2.2l s/w, has been
Filings caused by miss alignment of shaft/ bearings. Probably be ok wiuth oil changew and filter. Go for it. If it fails buy another trans from a wrecker out of a smash for a lot cheaper. Vectra is euro import. Best fix would be trade in while running ok.
Sep 13, 2009 | RTO Automatic Transmission And Engine Oil...
GEARBOX FOR VECTRA 2.5 V6 1997
if you look on the gear box there will be a stamp on it sayin f16,f18,f23 etc or ring your local vauxhall dealer and give them the reg regards
Apr 25, 2009 | 1997 Acura CL
Lost radio code for opel vectra
need a unlock code for radio in 04 vectra
Apr 11, 2009 | Car Audio & Video
Only way to check out the problem for sure is to drop the gearbox out and examine the clutch. Having gone this far in to the internal workings. It would make best sense to replace the clutch and pressure plates. Oil leaks can be repaired at the same time. No need to go to a main dealer because clutch replacement on a V6 is technically a very similar and no more difficult to replacement on any other Vectra
May 30, 2008 | 1997 Acura CL
Boxing Logo
147 people viewed this question
Top Boxing Experts
Karissa Smith
Karissa Smith
Level 1 Expert
Are you a Boxing Expert? Answer questions, earn points and help others
