Need voltage transformer for crosley mod. cr704c
Need to know secondary output
  • Audio Player... Master
  • 5,113 Answers
Transformers are safety parts so you need to get only the one authorised by Crosley, so you need to contact them for a supplier of the part.
Posted on Jan 16, 2013
2 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Transformer main coil shorted.
You have to do the math according to the circuit path, and all components in between. Break out the voltage meter.
Posted on Oct 28, 2007
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
May 09, 2014 | Intermatic Malibu 300W Power Pack...
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
Crosley CR24 transformer rating
As transformers are Safety parts they must be replaced by the excat same part or one that is approved by Crosley. You should not attemp to use another transformer unless it's approved by Crosley. Otherwise it could become a fire hazard.
You can contact them here:
http://www.crosleyradio.com/Support.aspx
Nov 17, 2012 | Crosley Cr42 Turntable
How to identify the matching transformer terminal by means of terminal resistance? and which terminals is for input or output?
Doing a resistance test on a transformer will not give the information you require as you will read very little, if any resistance. What you need to do is an impedance check and that gets involved. If it is a normally wound transformer, not an auto transformer, you can isolate which is the primary and the secondary windings. Unless the transformer is a multi voltage input unit, the primary side will have continuity through only two terminals. The secondary could be more than two if it is a multi output voltage one. If the transformer is a step down, the primary windings will be the thinner wired windings and vice-versa. To actually test the transformer, get hold of a transformer with about a 20 vac output and try it across the two terminals you have identified as the primary windings, you should ge a proportional voltage of the actual output. eg. with 20 vac input and a 2 vac reading at the secondary, the actual output would be 11 vac if your mains voltage is 110 volts. Take care that you are using the transformer at the voltage it is designed for, otherwise it will overheat and burn out.
May 11, 2011 | Kitchen Ranges
Model CR66, comes on full volume, tried cleaning volume control, no change. ideas?
Crosley Model CR66 does not come on. It appears the transformer is blown out. anyone know the correct output voltage of the transformer? barely a year old.
Dec 06, 2009 | Crosley Jukebox CD Player with AM/FM Tuner
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Transformer has failed in my Trutech M#KLV3112
The transformer should have the input and output rating labeled on the unit itself. Such as input 110vac, output ...... dc.
Jan 14, 2009 | Televison & Video
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
Crosley CR83 transformer needed
Hi Meggie58,
There are a few ways to repair the damage....
1/ Obtain a genuine replacement transformer from the Crosley
company in the USA. 120volts and you must then use a
step down transformer for the Australian power supply.
2/ Obtain a locally manufactured transformer that has a 230v
Primary but the secondary is matched to the Crosley power
requirements.
This can be sorted out by your service technician..
3/ Advertise in the "Wanted to buy" section of E-bay or any
other USA Internet trading post to obtain another CR-83
complete...
4/ Advertise in the "Wanted to buy" section of any Australian
Internet trading post to obtain another CR-83 complete....
(You just might get lucky)
Ensure the mains transformer is OK...
4/ Watch the internet trading post sites for another CR-83
complete and working "for sale" Buy that one then use your
existing one for spare parts in the future..(Excluding the
transformer of course).
Hope this Helps you... YUBEUT
Jan 18, 2008 | Crosley Arlington Stack-O-Matic CR83...
56 people viewed this question
 Grubhead
Grubhead
