Question about Royal TA Adler-Satellite 40 Electric Typewriter
Ribon will not advance - Royal TA Adler-Satellite 40 Electric Typewriter
  • Royal Master
  • 3,594 Answers
Look for debris in the carrier movement area. Then try a shot of WD40 on the silver shafts that the carrier slides on.
DickyO
Posted on Jan 16, 2013
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
5 new ribbons, 2 different typewriters, same issue: Ribon will not advance,
Go to brother.com, click on support, poke around there you will find a manual.
DickyO
Nov 07, 2010 | Brother GX-6750 Typewriter
Out of ribbon p330i Zebra
possible need to recalibrate the sensors, go to driver, and send the command !SA.
May 06, 2010 | Zebra P330i Thermal Card Printer
Maxtor D540X-4D 60GB 5400 RPM HDD is not detected on my computer management?i tried to use another PC but same problem occured. What should i do?
There is a jumper located near the power plug and on the label there should be a configuration table. Primary, slave or cable select. Double check to see the data ribon cable type the newer ones 7600 RPM I believe has a dense wire ribon texture for faster data transfer, I did not believe it when I first saw it eather.. I believe that may have to use the older standard ribon data cable. And check the config of that jumper
Jul 24, 2009 | Computers & Internet
My 1200p fax machine only prints half a page
This is a ribon transfer problem. Open the machine and see if the ribon has been mouving properly or fixi it inside the cartridge. GOOD LUCK.
Nov 21, 2008 | Brother Office Equipment & Supplies
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
Royal TA Adler-Satellite 40 Electric Typewriter Logo
69 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
