Question about Toshiba Satellite A135-S2386 Notebook
Upgrading Ram on my Toshiba A135 S2386 Laptop, still under warrantly
I recently bought a Toshiba Laptop from Best Buy. I alo bought an additional 1 GB of Ram ( same specification) from New Egg. However while trying to install the ram, I could not open the ram cover at the back of the laptop. I was ableto unscrew the cover, but it seems to be stuck with a couple of plastc latches on both side of the cover and I was could not remove it with reasonable force. Please suggest, how to replace the ram. and does it affect warrantly in any way.
    Scholar:
  • 39 Answers
Hi there. There are 2 locations on the border of the plastic cover, both on the same side. You need to use a small flat screwdriver or your nail, and lift the cover using those 2 spots. It will snap out of place ! If you hold the laptop upside down, the front of the laptop closest to you, the 2 places where u need to lift are on the right side. You need to lift on that side, and the plastic latches are on the left side only. Hope you see what i mean ! But basically, lift right side. Thanks ! cheebster.
Posted on Jul 09, 2007
  • Vincent Forcier
    Vincent Forcier Jul 09, 2007
    Here's a picture to help ! :)
SOURCE:
I need to reset the bios password on my daughters laptop
ReSetting Bios Password on Toshiba Satellite A135-S2386
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in upper left corner( laptop battery slot is on right, DVD drive is facing away from you)
5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is your ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Now hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding the ground(that blob of solder about 1/8"dia on both ends of the "silkscreen chip outline"
Sep 23, 2010 | Toshiba Satellite A135-S2386 Notebook...
My 3 yr old Toshiba - A135-S2386 - Vista - has
Just a suggestion................I have seen the RAM cause these problems in many laptops try your old RAM that came with it see if the problems persist....Good Luck
Jul 23, 2010 | Toshiba Satellite A135-S2386 Notebook
How do i change the ram in my Toshiba laptop. I
hi
this is kamal here to help u.
if u have screw driver so pls open ur laptop and change ur ram it's very simple and take risk...
best of luck
best regards
kamal singh
Oct 09, 2009 | Toshiba Satellite A135-S2386 Notebook
Default password thosiba a135-s2386?
remove the RAM ( Door under laptop) find the 2 metal bars or pins near or between the RAM slots and short them out with a paper clip.replace the RAM and that's it!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Toshiba Satellite A135-S2386 Notebook
How can I get a users manual for a A135-S2386 I bought a toshiba without a manual
download user manual from>>
http://www.laptops-drivers.com/laptop-driver/toshiba-users-guide-for-satellite-a135.html
Please rate this solution.
Thanks for using FixYa.
Feb 19, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Locks up
The reason your laptop is rebooting is due to a faulty RAM memory card. Replace your Ram Card(s) and all should be fine. Toshiba's are common for faulting due to damaged sectors in the ram cards
Jan 27, 2009 | Toshiba Satellite A135-S2246 Notebook
Any solution for the problem of my pc laptop(TOSHIBA Satellite a135-s2386...password required upon boot? kindly help...
There is a site to visit that may be of help.http://animesoftntech.blogspot.com/2008/09/solution-for-toshiba-satellite-a135.html
Jan 19, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
Wi-fi ability lost with RAM upgrade
It is possible that the WiFi card was dislodged or inadvertently snap out of position. Should you venture on a DIY, pls remove the bottom panel covering the memory and/or add-on cards. The WiFi card would be the one with one or two black or gray small cable/wire with connectors at the end. Unsnap the said WiFi card, partially remove/pull from the slot, re-insert and snap back. It may be necessary to wiggle a little bit to ensure that the pins are in contact with the corresponding slot pins. Thereafter, close the lid/panel cover and reboot the laptop.
Should problem persist, you may need to return the unit to whoever replaced the memory and present your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Toshiba Satellite A60 Notebook
XP compatible drivers for my laptop
dear, sir i have a notebook of toshiba satellite a135 psad0u-05400p i need compatible drivers of win xp plz hel me my email id is [email protected]
Dec 10, 2007 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
515 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
