Question about Samsung SC-D353 Mini DV Digital Camcorder
Fix my old cam vhs is broking - Samsung SC-D353 Mini DV Digital Camcorder
I have an old Panasonic VHS model PV 4551 that needs fixing. Is this a good machine or should I consider trying to find something else new?
An old VHS suffers from old belts and old rubber drive parts that will continue to degenerate. Sadly, these are disposable products and you'll get another 10+ years out of a new one for about the cost of the repair.
Feb 27, 2018 | Panasonic Televison & Video
Six years ago, I purchased my Sony Handycam CCD_TRV308 Hi-8. Now I want to download some old videos. Will this cam corder allow me to transfer videos to my computer?
You likely need a video capture card that will accept analog video (several makers like Pinnacle--not a recommend);
...alternatively, if you have a digital video camera, better ones have an analog video input jack by which you can use the digital camcorder as an interface (with analog to digital conversion), and thence to the computer via the firewire cable.
...This technique can also be used to transfer VHS from your old VHS player from its analog output, via the digital camcorder to the PC.
..This way you can transfer into a NLE (non-linear editor) like Adobe Premier, Final Cut, Sony Vegas, AVID, etc ; and edit your video now that it has been digitized. And the Hi8 as you know will have much better resolution potential than the VHS.
Aug 08, 2009 | Sony Handycam CCD-TRV308 Camcorder
Need to copy/transfer 8mm camcorder tapes or fix broken Camcorder
There is no adapter available because the tape size is different than VHS. If yuo can post a picture of the part that is broken, I may be able to locate one. I have a number of scrap units that I can part out. Please also indicate where you aer located in the country.
Thanks,
Dan
Feb 16, 2009 | Sharp VL-E600U 8mm Analog Camcorder
Broken Cam Gear
Thanks for model number update.
below is an image of VCR Mechanism used in this unit.
Part number details, exploded view of parts and timing information are available in related service manual which can be obtained from Manual Zone with little fee.
If you are familiar with VCR mechanical repair then it would be easy to fix.
You can check required part availability and price in Part Store.
I hope above info will help you to fix this unit. let me know if you need further info.
Feb 06, 2009 | Sony RDR-VX530 DVD Recorder/VCR
My vcr keep ejecting tape
If it keeps on ejecting tapes ,,that means the belt in there is wore out or slippin, or broke,, and it can be one of the springs that seats the vhs tape is stretched out or broke ,,,,, its always the case,, in the vhs .. there a pain to work on to.. good luck,,cheaper to probly buy one if you cant fix it your self,,thanks
Oct 05, 2008 | Televison & Video
Buzzing noise
could it be your monitor or tv??
try playing on another machine
i have and old vhs/tv combo that is use for my job
and i use to record on it around the clock as a security cam - so it has a lot of hours on it
when i record it like security cam -- the sound is going thru it just fine -- but when play back i have the buzz/roar
i was told by an engineer the heads are gon
Sep 27, 2007 | Sony RDR-VX555
Samsung SC-D353 Mini DV Digital Camcorder Logo
16 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
