Question about Water Heaters
Valliant turbomax manual
I need to download a manual for a valliant turbomax +824e can anyone help. many thanks ian
  • 30 Answers
Hi ian
most boiler manufacturers now days have downloadable manuals on there web sites.
just type in "vailant boilers" and flix through until you find the correct page. if they haven't a download you can request a copy on the "contact us" page .
i hope this has been some use
Posted on Mar 30, 2009
Intermittent hot water.Changed diverter valve,heat exchanger,fan, PCB. Vaillant turbomax 282e But still no hot water.
Sounds like you need a new Thermo coupler.
Could be as simple as a dirty pilot and needs cleaning but I suspect a thermo coupler.
Apr 14, 2016 | Water Water Heaters
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
No hot water
My guess would be the unit mifired and need reset.
Mar 10, 2009 | Water Heaters
Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Jan 20, 2009 | Water Heaters
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
The code E 13 comes up on the panel and it cuts out
Maximum temp exceeded on ntc1(thermistor),,,either clean out heat exchanger,power flush of my first option replace thermistor...
Nov 11, 2008 | Water Heaters
Water Heaters Logo
487 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
