Question about Life Fitness T3 Treadmill with TRACK Console
My t3 treadmill doesn't come out of energy saving.
The green light continues to flash slowly proving there is power in but it won't come out of energy saving mode.
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
Rese the treadmill and try again.
if the problem persist go to the MENU, and turn OFF .
God bless yo
Posted on Jan 14, 2013
  • Chris Lintern Jan 14, 2013
    How do I reset the treadmill? The console will not turn on, the energy saving green light simply flashes slowly but nothing else on the console turns on.
  • ernesto cuadra
    ernesto cuadra Jan 14, 2013
    the treadmills has Reset button to the side from main swithc.Try it and go on
5 Suggested Answers
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Posted on May 07, 2010
knight_nemes
  • 11 Answers
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
Posted on May 04, 2012
  • 59 Answers
SOURCE: my treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
My treadmill life fitness 9100HR won't start
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
Display shows LS1low speed code
hai ,
pls check 12pin communication cable and speed sensor wire also
Dec 13, 2011 | RTO Sole F80 Treadmill
My proform incline won't recline
Dear Sir:
I will try to help you.
Please see the video with patience and carefully. you nee basic tools+Dvom
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
With this you will fix it.
If you need further assistance, please reach me, sincerely.God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 26, 2011 | Proform XP Weight Loss 620 Treadmill
The incline won't recline
I will help you.please watch the videos, and use basic tools , patience , and carefully.
LED.
If you need further assistance, please reache, sincerely. God bless you.
E.CUADRA
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Life Fitness T3 Treadmill with TRACK Console Logo
99 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
