Question about Lanzar Car Audio & Video
Need rcone kit for opti drive 15in 1535d
The coil is bad its hard to find a recone kit i heard their might be a substitute
3 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: bad hard drive
puchase one vista cd/dvd and install no other option
Posted on Nov 08, 2008
  • 10406 Answers
SOURCE: I have nexxtech portable kit with a hard drive in
Try your NexxTech on some other computer, to verify that it still works.
Try some other USB port on your computer.
Try some other USB device into the same USB port that you are trying to use for your NexxTech, to make sure that your computer's USB ports are working correctly.
Check that Windows 7 has loaded the device-drivers for your USB 2.0 ports on your computer's motherboard.
Posted on May 14, 2010
Hi no up shift when cold
Have the codes read. Could be wiring. Only thing I can think of is the transmission temp sensor. When bad , the ECU reads it as -40 degrees. And will affect shifting. It needs to be scanned when cold and after it is hot. I have seen the temp be -40, then jump to normal operating temp. This was bad wiring on most. There were a couple that the sensor was upgraded 8 times. It was hard to find the newest upgrade.
May 01, 2016 | Cars & Trucks
How do i rebuild the voicecoil on my kicker l7 15in speaker
I dont think that kicker has a recone kit available for L7, after they started building the cone as a one piece structure without a dustcap, making it impossible to align the coil in the gap.
Myself, i have considered the possibility of using the carbon fibre maxxonics recone kits, it may need some tweeking to make it work. but will be quite strong and you could try different coil impedences, aluminum formers etc.
if you dont feel adventurous, than you might be able to send in your sub to kicker for service. i think they just send off a new sub to you, at a discount......
Apr 14, 2014 | Car Audio & Video
How do i fix a frozen 12 inch power acoustik FUBAR-12W sub
You have a case of a blown sub. You will need a recone kit. You ca send it in to a company like fix my speaker or google recone kits for Power Acoustik FUBAR. May be cheaper just to get another sub.
Oct 20, 2012 | Power Acoustik FUBAR-12W Car Subwoofer
I have nexxtech portable kit with a hard drive in it, it worked on windows xp, but winds 7 doesn't reconize it How do I fix this
May 14, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    Blown voice coil
    you will need to buy a recone motor kit for your sub
    Jul 04, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
    I have 15" subzero earthquake and i need to reconed
    Usually the voice coil is bad on these subs...if your surround is rotted or torn - EXTENDING YOUR FINGERS PUSH DOWN GENTLY ON THE MIDDLE OF THE SUB AND RELEASE...Is it free? If not, forget the rebuild...If you need a kit for rebuilding the Earthquake...try Googling "Lesco Distibuting" in Orange City, FL and ask them who their closest Earthquake dealer is.
    Good Luck
    Jun 15, 2009 | Orion 15" Competition Subwoofer H2 15D4...
    Does not reconize hard drive
    turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
    May 18, 2009 | Dell Inspiron 2650 Notebook
    Bad hard drive
    Oct 28, 2008 | Acer Aspire 4520-5582 Notebook
    Can i put a new voice coil in the woofer of my JBL 4410?
    It is possible to recone this speaker. Get a recone kit from JBL. It takes a little practice, but reconing can be done. I have done hundreds over the years. Make sure that you get the kit from JBL. If you feel that you don't want to take a chance on this there are reconing shops around the country.
    Dan
    Sep 06, 2008 | Audio Players & Recorders
    Car Audio & Video Logo
    22 people viewed this question
    Top Lanzar Car Audio & Video Experts
    Joe Alexander
    Joe Alexander
    Chris Ward
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
