Question about General Electric GE JTP55SMSS Electric Oven
JKP27WP GE ELECTRIC OVEN SHOWS F1. WHAT DOES IT MEAN?
The top oven is flashing F-1
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Flashing F1 and beeping, on a GE JRP15 Electric Single Oven. What does it mean?
This is usually a control board failure, but sometimes can be caused by the keypad. There is a procedure outlined in the tech sheet to determine which it is.
best regards,
Bruce
www.fixyourboard.com
Jun 15, 2010 | GE JRP15 Electric Single Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
F-1 READING ON OVEN
im not sure what f1 is. have you tried turning off the oven at your switch board for about 5 minutes and turning it on again?
let me no how that goes and in the mean time i will try to find out what f1 is
Feb 19, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
General Electric GE JTP55SMSS Electric Oven Logo
54 people viewed this question
Top General Electric Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a General Electric Oven Expert? Answer questions, earn points and help others
