Question about Zanussi TC7102W Electric Dryer
Dryer problem i have a hotpoint tumble dryer model tl61p thought i had solved the problem by buying a new piece of bearing felt 1 day later its worn again now it looks like the drum has dropped wot is my problem
  • Zanussi Master
  • 3,463 Answers
You need to replace the rear drum bearing, and also the plastic bearing pads at the front of the dryer, where the drum goes round against the front panel.
There is a repair kit that contains all the parts you need to carry out this repair, with instructions on what to do.
P
It does involve stripping the dryer down to complete these repairs.
Posted on Jan 25, 2009
How do I replace the belt on my hotpoint futura tumble dryer?
I can't answer your question exactly but in my experience tumble drier belts are not particularly complicated to replace but the process is fairly time-consuming and involved as in order to slip the new belt over the drum an almost complete strip-down of the cabinet is needed.
It is a route-march of removing screws and plastic trim until something important falls off. The task then becomes rather more a thorough interior clean and a changing of felt bearings than merely replacing the belt. The belts last so long that by the time they need replacing the other things are also ready for attention.
Apr 29, 2016 | Hotpoint Dryers
My Hotpoint tl61p tumble dryer made a loud bang, and now will not work, the timer justs buzz's? can anyone help please?
The load bang you heard was the idler pulley slamming into the frame more than likely. this is because your belt broke removing the tension suddenly. Put a new belt on and you'll be fine.
May 08, 2012 | Hotpoint Dryers
I have a vented TL61P Hotpoint Aquarius tumble dryer which will not heat with or without the no heat button pressed !Could this be a thermostat problem or the heater ?
check thermostats as above posts have commented check also condition of elements as my dryer elements are cracked and need replacing just had a new belt fitted so reluctant to let it go
Mar 19, 2011 | Dryers
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
My hotpoint cdt00 tumble dryer makes a loud banging noise on each rotation what is causing this
It is probably a worn rear drum bearing, remove cover of drum shaft, and examine the drum shaft for wear.
Jan 17, 2010 | Hotpoint Dryers
Hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Nov 19, 2009 | Hotpoint Dryers
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
Noisy Zanussi TD260 Tumble Dryer
If the motor is ok the next thing I would check is the felt strip which is on the rear of the drum and is usually glued down. When this gets worn the noise can be really intolerable. You can buy new felt but the drum has to be removed in order to replace it. Not a fun job!
Jan 28, 2009 | Dryers
My dryer dries but it shrieks. Do I need to buy a new one? Is it worth it to have it fixed? Thanks!
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through and metal showing
replace both rollers or both felts if one is worn
roolers are bout $9 /pair
felts can be anything the manufacturer thinks they are worth
Aug 28, 2008 | Maytag Dryers
Tumble dryer fault
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TC7102W Electric Dryer Logo
177 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
