Question about Fujitsu Siemens LifeBook A Series Laptop Universal AC Adapter 18-20v (AC22VPN26P2YR)
Black screen
Laptop will switch on but wont boot up. tried running the recovery disc but theres no way to restart the laptop. tried f8 but get nothing just takes me to a black screen
  • 2 more comments
  • anthony butler Jan 15, 2013
    i can see post messages that you're talking about removed battery pack and nothing i get the fujitsu logo at start up then black screen
  • polyal Jan 15, 2013
    have you removed and replaced the internal 5v battery ( this maintains the bios setup )or if you can enter the bios set everything to default
  • anthony butler Jan 21, 2013
    i done that aswell so i got in touch with the company i bought it from and i am waiting for a replacement as i only got it for christmas
  • polyal Jan 22, 2013
    if you only bought it a christmas then its still under warranty and you should have consulted the retailer from the outset
    Problem Solver:
  • 3 Answers
Can you see any POST messages when you first turn it on?
ie amount of ram / discs etc..if not try connecting an external
monitor it might be the screen malfunctioning
also is your psu generating the correct voltage ( 18-20v)
if you can , remove ( for 20secs then replace) the internal 5v battery to reset the bios..remove the battery pack and power first though
bottom line is..your mobo could be f****ed or your bios corrupt
best of luck
Posted on Jan 14, 2013
In recovery mode and lost power, then battery went dead. Now turn laptop on get the ASUS logo , in center, and Intel Logo, lower right corner, on black screen. Then black screen comes on again with...
Take disk out. Power down. Restart. See if will start up without a disk in it. Might be confused by your disk. Did you try to F8 or F9 while restarting to get into BIOS (trying to remember which one will boot you to BIOS). Then see if the CD/DVD was disable for boot up. Turn that back on if you can get into BOS so it will boot up you recovery disk.. If your OS is completely gone, you will have to reinstall...
Sep 24, 2013 | ASUS K Computers & Internet
Compaq Preario CQ56-115DX Notebook wont restart
If your bootmgr is missing and you have windows 7 you should have a repair partition that can be booted into using the F8 key when powering on your machine. If not, you will need a repair/recovery/installation disc to boot from
Mar 23, 2013 | Computers & Internet
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
Toshiba U400 - when switched on the toshiba logo will appear and followed by a black screen. kindly help me with this problem. I tried F8 but F11 and pressing to reboot but nothing happens.
This probably means it can't boot off the hard disk or the CD ROM.
Make sure there's no CD in the drive.
Try holding F1 as you turn on the unit to see if you can get into the setup if it still won't boot with no CD.
Feb 28, 2011 | Toshiba Computers & Internet
Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
Aug 27, 2009 | HP Compaq Presario CQ60-249US Notebook
Not booting up
Unfortunately you Windows OS crashed. Try pressing the F8 once you boot up. It should lead you to an option screen where you will be choosing SAFE MODE only. If you can boot up to windows under safemode you can do system restore or uninstall the program you just installed.
If you can't go into safe mode. Use the recovery disc. Pop disc 1 then upon booting the computer, press F12 to load boot menu then choose the dvd/cd drive. Once it finished loading, choose advanced option instead of Toshiba recovery wizard and it will lead you to system restore.
If both of the steps failed, unfortunately, you need to do full system recovery. Just do step 2 and choose Toshiba recovery Wizard, Out of the box state. This will delete all your data.
hope this helps.
Sep 12, 2008 | Toshiba Satellite A45-S151 Notebook
ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
Nov 06, 2007 | Acer Aspire 3680 Laptop
Fujitsu Siemens LifeBook A Series Laptop Universal AC Adapter 18-20v (AC22VPN26P2YR) Logo
69 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
