Strapping or Jumpering for slave
I have a temp laptop while mine is out for repair, I would like use my hard drive as a secondary/slave. Can I strap it? What pins would I use.
  • fish2forbass Jan 30, 2009
    i have a WDC WD4OOEB-11CPFO 40gb plus a Seagate ST3250820A 250 hard drives my problem is which one to use as a primary drive and where dose the jumpers go on the drives for cable select and how to format the drives, im a computer dummy so please help me as much as you can, thank you. my name is Frank
I have a WDC WD400EB-11CPFO HARD DRIVE 40GB PLUS A SEAGATE ST3250820A HARD DRIVE 250GB MY I WANT TO INSTALL A SLAVE BUT DON'T WHICH ONE TO USE AS A SLAVE 40GB OR 250GB ALSO DON'T NO WHERE THE JUMPERS GO ON EACH DRIVE IM A COMPUTER DUMMY SO PLEASE HELP ME AS MUCH AS YOU CAN THANK YOU MY NAME IS FRANK BOT DRIVE FOR INTERNAL
Posted on Jan 30, 2009
    President:
  • 1,179 Answers
You need the system info for the laptop you are using to see if a 2nd hdd needs to be set as slave or set in the cable select mode. Either right above the jumper pins or on the top of the hdd above the pins you should see 3 groups of 2 pins. They will be marked, ma, cs, & sl. They may not be in this order as each hdd manufacturer is different but all will have those 3 markings. If you set as slave cover the 2 jumper pins marked sl. For cable select cover the 2 pins marked cs. Hope this helps & please remember to rate my answer.
Posted on Jan 23, 2009
2 Suggested Answers
kman203
  • 99 Answers
SOURCE: Strapping or Jumpering for slave
Best bet is buy an external enclosure to pur the extra hard drive in. Easiest solution. Cost about $39-$49 at electronics store.
Hope this helps!
Posted on Jun 11, 2008
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
May 04, 2011 | Western Digital Caviar WD200BB 20 GB Hard...
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
Can the Deskstar HDS721050CLA362, 500 GB hard drive be forced into 1.5gb mode by jumpering the pins on the drive?
> 1.5GB
Did you mean 1.5 TB (1500 GB) ?
Anyway, no, the jumpers only are for MASTER or SLAVE or CABLE-SELECT operation.
Dec 30, 2010 | Hitachi Computers & Internet
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Hope this helps!
Jun 11, 2008 | SimpleTech (STI-HD2.5/40A ) (STIHD2540A)...
Computers & Internet Logo
676 people viewed this question
David Payne
David Payne
