Question about Kitchen Ranges
Have a frigidaire convection range model#CFEF388CES-3 Type 385. How do I start the self cleaning function,bought used and do not owners manual
There is no clean button, but 2 of the knobs have a lock icon. Tried setting the knobs on the lock icon and pressed start.
Richie_asg1
  • 1036 Answers
SOURCE: We just moved into a
Hi, The E1-F5 code means that there is a problem with the door locking circuit.
Try moving the door lock if access is easy. - then turn off at the wall for 5 minutes to reset.
There could be a faulty connection with the interlock switch or the drive motor. With the power off, Check the switch operation first. It could just be a faulty contact.
To access it, you have to rise the top to access the latch if the motor is bad. There are screws along the front edge when you open the door. These need to come out to lift the top. Take care not to lift too high as you may crack the top.
Posted on Jun 29, 2008
SOURCE: I have lost my manual to my GE Profile Gas Range, self cleaning, convection and conventional oven
what does f2 mean when I am self cleaning my ge profile oven.
Posted on Dec 29, 2008
  • 22 Answers
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Posted on Mar 31, 2009
SOURCE: I have no manual and do not know how to use
The latch wouldn't go all of the way over. I pushed it over until the blinking light went off. The latch doesn't seem to catch but I did get it to work. Thank you for your help though.
Posted on Apr 10, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
I have a model fef365asd range and the owners manuel.
Hey friend, thank you for the post!
I understand you are seeking the manual of your Frigidaire range, FEF365ASD. I have successfully located the Owner's Guide. This link should direct you to the information you are looking for. I hope this information proves useful. -Matt
Frigidaire Product Manuals
Jul 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Cant get the oven to turn off from the cleaning setting and its just making a loud beeping sound, had to unplug.
After unplugging, allow the oven cooling down for few hours.
If the beeping restart, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 02, 2010 | Frigidaire Gallery 30" Self-Cleaning...
How long does self cleaning take?
Self clean mode can vary between makes and models of kitchen ranges, but it usually averages 2 to 4 hours. Once the self clean mode has been started it cannot be stopped until it completes the cycle and cools down. The oven door will lock and will not unlock until the internal oven temperature cools as the oven will super heat to about 700 or 800 degrees. Some manufacturers will enable the consumer to vary the self clean cycle time. Refer to your owner's manual under the Operating Instructions for specifics.
If you no longer have an owner's manual, you may be able to obtain one on line at managemylife.com. Just type in your model number under the "Manuals" link and see if it is listed. They have an extensive list of owner's and installation manuals available in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 04, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Self cleaning instructions
Hi. i have created a link for you to access the actual manual you are needing. please feel free to print it out or, save it to your CPU for safe keeping.
Click here for your Frigidaire manual.
please rate and god bless.
Mar 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How to use self cleaning
It would be wise to not use the self clean mode. Many horror storys of controls costing hundreds of dollars to replace come to mind. The delicate electronics cannot stand the 900 degree 3 hour endurance of this. Why not get some green flavored easy off oven cleaner instead and save a lot of money. They have a new and improved easy off citrus based product that is deemed green and mean.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Need directions for fridaigre self cleaning oven
i cannot find the model number on my frigidaire self cleaning stove.i need to know how the self cleaning works.i bought the stove used
Nov 26, 2008 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
