Question about Oreck XL® Classic Bagged Upright Vacuum
The brushes are not spinning - Oreck XL® Classic Bagged Upright Vacuum
It sounds to me that the drive belt to the brush is broken. To verify, or replace, you must take off the bottom cover.
Posted on Jan 14, 2013
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
    Kristie,
    I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
    Apr 05, 2015 | Hoover Vacuums
    Why is my Shark nv500 vaccum carpet brush is not spinning?
    I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
    Aug 01, 2014 | Shark Rotator Professional Lift-Away...
    My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
    Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
    Search Results
    Hope this helps!
    Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
    Oreck magnesium keeps shutting off
    Need to check your brush roller to see if it is spinning. Turn the vacuum over and turn it on. If the brush spins before it shuts off, you may need to check the bearings to see if any strings or hair has built up around the brush bearing shafts and is causing the brush to spin slower. If the brush does not spin, you have a broken belt and you will need to replace it. The Magnesium has a sensor that looks for the brush to spin at a certain speed and if it does not, it will shut down. Hope this helps!
    Apr 12, 2014 | Oreck Vacuums
    My spin brushes are not spinning. Took out the spin brush attachment - the main port that the attachment plugs into is not spinning. Is this repairable?
    Sometimes it can be the inside rod of the brush barrel has resonated hair build up preventing the, what appears to be clean, brush. Check to see if either end of your brush wheels has a nut or can unscrew to clean inside it.
    Sep 01, 2011 | Hoover Vacuums
    The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
    Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
    Sep 05, 2010 | Bissell Cleanview Helix Vacuum
    I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
    Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
    Jun 24, 2017 | Vacuums
    Eats belts immediately
    HI There,
    Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
    To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
    Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
    If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
    Hope this helped you,
    Chris Jones
    GoVacuum.com
    May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
    Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
    Hi There,
    When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
    The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
    Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
    If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
    If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
    Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
    The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
    I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
    Thanks so much,
    Chris Jones
    GoVacuum.com
    Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
    Oreck XL® Classic Bagged Upright Vacuum Logo
    47 people viewed this question
    Top Oreck Vacuums Experts
    xalint1
    xalint1
    Kory Ronning
    Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
