Question about Frigidaire Electric Dryer
Frigidaire dryer gallery series wont spin
Dryer was running, started squealing, then stopped spinning. Can't even spin it by hand. I'm guessing a belt broke but how do I get to it and fix it?
  • Official Brand Answer
  • 4,342 Answers
Hello Hannah Kottman - Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed. Contact a professional to move forward accurately.
Posted on Jan 15, 2013
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
AlmostBob
  • 550 Answers
SOURCE: I have a Frigidaire gallery
the dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
7713ef8.jpgce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, and clean out the ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Posted on Oct 23, 2008
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Posted on Feb 21, 2009
  • 1531 Answers
SOURCE: Frigidaire Gallery front load dryer. 6 yrs old.
Yes this can be place but you have to replace the whole switch they are not very expensive but the knob can cost as much as 14.00 dollars.
Posted on Sep 26, 2010
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Frigidaire gallery series electric dryer/washer. Dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Frigidaire Dryers
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
88 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
