Question about Bosch Washing Machines
Bosch Washing machine brush replacement. Bosch WF02866GB Need to replace motor brushes I think. Back panel is small and although I can see the motor I think I'll have to roll it over and remove t
5 Suggested Answers
gittos73
  • 244 Answers
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Posted on Feb 25, 2008
  • 1462 Answers
SOURCE: Where are the brushes?
easiest way is to remove the motor - just held in by simple bolts. disconnect the electrical plug and socket wiring to the motor of course.
Posted on Oct 01, 2008
  • 7 Answers
SOURCE: brush relacement in bosch wfl2450 washing machine.
yes the brushes do have to go in a particular direction.
imagine that the flat surface of the brush's angled end has to make full contact with the edge of the circular commutator down inside. Once you've got one brush done, the other one is inserted with its end situated in the opposite way. Like so, sort of: ----\ O \---- !!!!
hope that makes sense
Posted on Aug 06, 2009
barkencoa
  • 3463 Answers
SOURCE: HI. I have a bosch wfo2466 washing machine and
You do not need to remove the end cap.Pull off the brush leads, and ease out the terminal ends of brushes with a pair of taper nose pliers..pull the old brushes out, take note of which way the shamfored end of the brushes are facing in the holder.
Push new brushes into holder and compress the springs as you are pushing them down, locate terminal ends into slots of brush holder.
This should help you with your problem.
Good luck.
Thankyou.
Posted on Nov 27, 2009
I have a Bosch WFL 1200 front load washing machine. I need to replace the brushes on the motor. This model only has an "oval" shaped panel at the back. The side and back panels are all one piece and c
ALWAYS disconnect electrics....You need to access the motor from the bottom of machine.as it is a pig to work on if you try to replace the bushes whilst in situ...what I do is empty the machines residual water from drain tube bottom front then remove back.... undo belt .... Then lean the machine at 45degrees to one side and undo the two retaining bolts on the pulley side .the whole motor will slide toward rear of machine but uncouple the electrics block first then remove motor.the brushes are spring loaded and the brass clip slides one way to release?there are plenty of YouTube tutorials on bosch washing machines that show brush replacement.good luck.
Jan 29, 2015 | Bosch Washing Machines
My washing machine is not spining
It is likely that the Carbon Brushes of your Bosch washing machine need replacement. Get them from your nearest Bosch Spares stockist (P/N: 154740) Replace these on the motor armature, and it will be alright again. To be certain that it is indeed the Carbon brushes, open your washing machine and look on the motor (opposite side of the pulley) There has to be 2 grayish chalk type brushes running on a copper armature, these brushes have a lifetime of about 4 - 6 years before being diminished.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
Drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
Nov 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine drum doesn't turn or spin
Hi. I have just had the same fault, and as described elsewhere, the solution was to replace the motor brushes. I would say this took 1/2 - 3/4 hour to remove brushes and same to replace.
How:
1.DISCONNECTED ELECTRICITY SUPPLY
2. Disconnected water
3. Removed the 1 screw from back panel, removed panel to get access to remove belt.
4. Lay washer on it's side (2 people recommended)
5. From underneath machine, unscrewed 2 bolts on the motor (back of the machine)
6. Holding the motor so it did not fall and get damaged, carefully tapped end of motor to unmount it from holding pegs (slides towards back of machine)
7. Noted how the plastic cover fixed to motor, then snipped tie wrap holding it to motor.
8. Unplugged connector and earth connector.
9. Carefully removed connector on each brush.
10. AS THE BRUSH WAS SLOWLY WITHDRAWN, checked the orientation of the bevelled edge of the brush relative to the motor so the new one was fitted correctly (the end of the brush is angled so it sits flat against the motors commutator)
11. Replaced brushes and refitted in reverse order.
Oct 19, 2009 | Bosch WFL 2062 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Thanks.
Jan 05, 2009 | Washing Machines
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My bosch washing machine wfo2865 exxcel is not spinning. Every thing else works. The engineer said it could be the brushes. How do I take the motor out to replace the brushes
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Aug 07, 2008 | Bosch Washing Machines
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
76 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
