Question about Sansui Hdlcd1955w
Black screen when windows starts to load
Can see initial start up but when widows starts to load screen stays black
    New Friend:
  • 4 Answers
U should be more specific my freind but as i understand that it is a problem of resolution or refresh rate so boot the pc with another monitor & try to change the resolution & refresh rate to a desirable for ur lcd
Posted on Jan 14, 2013
  • aobishop Jan 14, 2013
    how do i change the refresh rate. can it be changed just don't understand refresh rate wich should be at 60 res at 720
  • aobishop Jan 18, 2013
    all set thank you for guiding me in the right path was quite simple
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Start up problem
Sounds like you need to do a complete system reinstall or bring it in to a repair shop and have them see if they can fix it for you.
Jun 25, 2012 | Acer TravelMate 220 Series Laptop Charger...
Well when i login to widows the screen stays black and then a box comes up and says (wuauclt) has stoped working windows is collecting more information about the problem then it says windows cannot solve...
WUAUCLT -- Windows Update Automatic Update client somehow has "crashed". It runs everytime that you restart Windows. It connects to Microsoft to look for the latest Security Updates to keep your computer protected and up-to-date. Start Internet Explorer. Click 'TOOLS' and click 'WINDOWS UPDATE'. Does this version of WINDOWS UPDATE run properly?
Jun 04, 2009 | Acer Aspire 5315 Notebook
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Start up problems with Sony Vaio VGN-A517S
remove your screen saver program form computer.go to control panel in settigns u se dispaly open it then set desktop as win xp.
Feb 03, 2009 | Sony VAIO PCV-J200 PC Desktop
LOGON PROCESS INITIALIZATION FAILURE
Assuming you are using Windows XP. There's some file corrupt or missing when you start your pc. If you have floopy disk you can boot disk, it not your can insert your Windows XP installer and then you can repair you OS.
Jun 26, 2008 | HP Pavilion dv6000z Notebook
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Acer 3690 hangs with black screen
hi , check if u can run the system in :"safe mode with VGA"option, or just the safe mode???if it works in safe mode, u will need to restore the O/S to previous checkpoint, or reinstall the OS using "repair" option.let me know
Jan 14, 2008 | Acer Aspire 3690-2196 Notebook
Sansui Hdlcd1955w Logo
66 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
