Question about HP mx705 17" CRT Monitor
Monitor goes standby after boot
I have an HP mx705 CRT, with only a year and a half of use on it. The monitor turns on and displays fine during boot (black Windows screen), but turns to standby with a yellow light right before it switches to what i think would be the login screen. I've seen a few problems in the forum that had an inverter board repair as their solution, but my monitor just goes to standby rather than going blank with a green light - which seems like a software problem. I have no idea what the source of the problem would be - I've tried this monitor on other computers as well, with the same results.
    Scholar:
  • 36 Answers
Look the problem it may not your monitor it's your windows XP. Let me guess you have a VGA/Svideo card. From prior experience I can tell you that dual output Nvidia cards will default to Svideo first, and then "adjust" your windows settings to do so every time even if a VGA monitor is re-connected (HIGHLY ANNOYING). So if the last thing you see before nothing is the Windows XP boot screen, here's how to fix it. Boot to safe mode uninstall your video driver, reboot then reinstall. You can substitute a system restore for uninstalling your drivers if you can remember when the monitor was last working. This really really pissed me off when it happened to me.
Posted on Jul 09, 2007
Monitor goes to standby after booting up.( Amber light)
I'm going to guess that your monitor has different imputs and maybe you aren't selecting the right one? There is usualy a button to change imputs on the monitor. If there is no signal and you've checked all the channels, the cable your using might not be functional or your monitor might be broken.
Apr 18, 2010 | HP mx705 17" CRT Monitor
Monitor continuously displays the menu option
click on the monitor menu button and change settings after save and exit.
Jul 09, 2009 | HP mx705 17" CRT Monitor
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Mar 09, 2008 | HP mx705 17" CRT Monitor
Monitor dims
Your monitor in hardware problem front panel keys short in side.change menu switch on boar.or command section problem.check ic or componets relate it.
Mar 03, 2008 | HP mx705 17" CRT Monitor
Flashing Green Light on mx705 monitor
If the HP has onboard video but you have an add-on video card, remove the add-on and connect the monitor to the onboard vid. If it works you have a bad add-on video card. If it doesn't or you are already running on on-board video hook the mx705 up to a compatible HP. The older PB may be TOO old to handle it or not hve the correct drivers.
Feb 25, 2008 | HP mx705 17" CRT Monitor
Hp ms705 menu comes on without prompt
Even my monitor HPM704 does the same thing from 12Mar08. I bought this monitor an year before. It looks like this batch of monitors have issues from factory itself. Plan to get support from customer care.
Dec 28, 2007 | HP mx705 17" CRT Monitor
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
HP mx705 17 in.CRT --Blank monitor
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system?  Put your ear to the monitor, any strange whinning noise?
Oct 22, 2007 | HP mx705 17" CRT Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
HP mx705 17" CRT Monitor Logo
590 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
