Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
Black screen, but sound
Hi again. Black screen, but sound. Changed the GE2-card, still black screen. Got help here earlier, someone said it could be the power supply 24vDc. Where is that located? Whats the name of the curciut bord? When the power is on (green diod / light), the screen is dark. If I touch the screen, white "clouds" pops ut the places I touch. Any ideas? Please advice :) Eirik, Norway!
  • 4 Answers
Maybe it is the panel eeprom,if the panel inverter is good which should be treated with experts
Posted on Jan 14, 2013
  • 2,318 Answers
The failure with this LCD is a defective T-con board. If the T-con board is Samsung LJ94-00877E(400W2C4LV2.5), I would suggest to check F1 for open condition. Replacing the fuse fixes the no video, blank screen but sound or replace the entire board if available.
Posted on May 17, 2015
  • 5 Answers
SOURCE: Black screen, no picture but have sound
the screen is on its way out
Posted on Jan 22, 2009
  • 34 Answers
SOURCE: Sony Bravia KDL-S40A12U Blank screen
Hello
on your set there is inverter board that is what lights up th backlight on your TV making everything visible that board has went bad.
Thankyou
Posted on Jul 28, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
I have a Samsung television that went black today. I thought it might be the station so I swithced it and the problem was still there. Can you help me find the part I need to fix it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size..
May 12, 2017 | Samsung Televison & Video
Watched tv earlier and the picture went black and sound remained
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 29, 2015 | Hitachi Televison & Video
I got a Samsung HDTV model LN40E550F7F.TV will not power on. The Power light is flashing First flash is bright and flash following is dim then back bright then dim.etc non stop.i looked at power supply...
Hi Ricky, Power supply card seems to have gone bad in this case.If you are technical, try replacing power supply board or consult someone qualified to handle your set.
Aug 24, 2014 | Televison & Video
I have an acer aspire 5100 with a black screen, won't boot and wont beep also, the fan run the system seems to be running i tried changing the hard drive i tried to clean the ram and place them back again...
if you have power it's not the power supply. It sound like the screen maybe gone on your laptop. Have tried hooking up a monitor to your laptop to see if the screen will come up?
Jan 20, 2011 | Acer Aspire 5100 Notebook
Power on - Screen Black non responsive
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Apr 22, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No picture or sound sceen is black
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
Mar 13, 2010 | Vizio L32 32 in. LCD HDTV
GA-8IHXP won't boot... VER 3.0
The next thing I would check is a close inspection of all the bad capacitors on the board. If you need an idea of what they look like check here.
May 23, 2009 | Gigabyte GA-8IHXP Motherboard
Compaq presario evo 1015v
sounds like a bad screen this might be able to be remedied by hooking the laptop straight to a computer monitor threw the ports provided in the back
also you could have bumped something loose inside like a video card if any cards or memmory comes loose this will give you black screen of death the laptop will have to opened and cards pressed down gently
theres the solution of your power supply on the laptop went out and you need a replacement
if power supply went out it doesnt hurt your comp it just makes it hard to run
May 21, 2008 | Compaq Presario 900 /1500 Series EVO...
Black screen problem
I sounds like your back light is out it looks like you might need a new lcd.
I repair digital camera
mike@digitalcamrepair.com
Feb 20, 2008 | Casio Exilim EXZ75 Digital Camera
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
285 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
