Question about Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS)
Trying to connect to my wireless router....but usb is not seeing
I had hired somebody to install approx 1 year ago...since then, I have
only had to repair connection. This time completely cannot connect.
I then called linksys whom the wireless router is from, and we went thru all steps required, and is working fine.
He told me it was probably the usb adapter I have, or may be lost
connection settings. Not sure.
I have been trying to figure out connection and may have changed many things by mistake.
Help Help I have tried to reach the 1 800 685-7655 Encore Support to
no avail. Maybe that number is for United States Only? I live in
Ontario Canada
  • 700 Answers
Try your USB adapter to another pc to check if it still works. If yes, maybe you should uninstall then reinstall its application and driver. I think this type have an auto detect.
Posted on Apr 13, 2009
I installed the compact wireless g usb adapoter on a desktop in basement of my house approx. 2 years ago and it was fine. I need to tell you that at that time I had satilette iwth wild blue and a linksys...
My experience is limited with such things.
Connecting the computer to the router with a cable I found was an instant success with three different routers and two different service providers (and several computers).
I fitted a couple of generic wireless adaptors also without incident. Each wireless adaptor arrived with a mini disc and instructions to load the drivers before plugging in the usb adaptor and ten minutes larter I was looking at a list of available wireless networks and being asked to choose one and the enter the password that is written on the underside of the router.
Once I used the Windows wizard to set up a wireless network and similarly had no trouble. I don't think it is necessary to configure the computer to a particular modem and I have not heard others speak of such a thing. Apart from needing the driver for the usb wireless adaptor there it all should happen automatically
Once the driver is installed and the adaptor plugged in, it should be obvious whether it is working because it should detect nearby wireless networks - but it won't connect with any of them unless you click on a particular one. It will only be possible to connect to open wireless or the one or ones you have the password for.
Once the computer is connected it should get the IP address automatically and then connect to the internet..
I have a sneaking suspicion you are thinking too deeply about this. The internet these days is almost foolproof - it has to be for me to get it to work.
Perhaps your operating system is seriously corrupted...
Mar 08, 2017 | Linksys WUSB54GSC Compact Wireless-G USB...
I installed a wireless router,but it only worked for a little while 1 day approx then it would not connect to to any wireless devise i had already connected to before.
Did you try pushing the reset button for 10 -15 seconds to return it to factory defaults?
Also check the the firmware is up to date.
Mar 16, 2010 | Linksys WRT160N Wireless Router
My hp lap top wont connect to the internet through the usb the ethernet or wireless and it was working fine until 24 hours ago. I think it may be the network adapter. I re installed the driver for it but...
Try turning off the wireless router fo 30 secs and then power it up again. When the LEDs light up, then boot up the HP laptop.
If this doesn't work, then check the laptop to see if the wireless router issued the HP laptop with an IP address. to do this - click on Start - Run - type cmd and press Enter. This will open a DOS command box, then type ipconfig and press Enter.
If the IP address returns 0.0.0.0 then the wireless router didn't issue the HP with an IP address and either the wireless router is faulty or the wireless card is faulty or it has lost its LAN configuration.
If the wireless router LEDs are all on, try connecting a LAN cable direct to the LAN port on the router and the laptop to see if it connects to the Internet. If it connects then install the latest wireless card driver and configure it with the wireless router's settings.
Jan 25, 2010 | HP Computers & Internet
The WPN111 RangeMax wireless UBS 2.0 adapter I bought a few days ago keeps disconnecting. At first the connection is fine throughout the day, but at night the connection fails. Internet access in the...
Do you have a good signal strength with the wireless USB adapter?
If not try moving the wireless router away from walls or metal objects and cordless phones, locate the wireless router higher.
See if there is a later driver for the wireless USB adapter, if so download and install it.
Dec 21, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
. 3 years ago, I loaded wireless broadband with a
ok you can buy a netgear rooter adopter from pc world ..make sure you get the model number...it works like a dream...:)
Aug 31, 2009 | Samsung NC10-14GW Notebook
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
Loses network connection or says low connectivity.
hmmm... need to see if this is from the router end or the problem is your laptop. phone company replaced the router-- did they stick around long enough to see you connect to it with your laptop?
how long has the connection worked properly between the wireless laptop and your basement router?
can you visit a starbucks or whatnot to see if you can surf with your latop (i.e. it's not your laptop wireless card)
can you get a friend to come over to try your router with their wireless laptop?
what if you stay just in teh basement -- does the connection drop at all?
Jan 31, 2009 | Sony VAIO VGN-FS742/W Notebook
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Di 524 through speedstream 5200: wireless connects but no browse
try re-installing the driver for your USB adapter or create a new wireless network name.
You could also try to download the latest driver for your USB adapter. uninstall the old driver before installing the latest driver for your USB adapter.
Jan 04, 2009 | D-Link AirPlus DI-524 Wireless Router
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Encore ENUWI-G2 802.11G WIRELESS USB 2.0 ADAPTER (54 MBPS) Logo
170 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
