Question about HP Pavilion ze4300 Notebook
Wont start Will not start. Tried restart No good. Battery is charged
    Champion:
  • 219 Answers
Sounds like a power supply problem..But not that familiar with laptops..
Posted on Jan 24, 2009
My 2002 pontiac montana security and battery light flashing and now it wont start
you could have a bad alternator not keeping the system at the appropriate level of charge. Or check the battery, replace with other known battery that is good and see if this fixes the problem. Clean all battery terminals. Dead shorts in battery can really create problems and sometimes can load test good but on the low side. Try the battery swap first if you have access to one
Apr 18, 2013 | 2002 Pontiac Montana
Alternator tests good wont charge battery
I'm sorry to say it could be the computer.
The computer controls idle speed as well as alternator output.
If the check engine light is on you should get it scanned for trouble codes.
Dec 18, 2012 | 1998 Dodge Stratus
Battery is dead and wont start
Make sure the battery is fully charged before trying again. If the battery wont charge get a new one. Once installed use a multimeter to verify that the alternator is charging.
Sep 22, 2012 | 2004 Chevrolet Chevrolet TrailBlazer EXT
I left the ignition on and the battery went dead. now the battery wont hold a charge. i can charge overnight starts right away. ride for 30 mins. turn off and it wont restart.
Is this an acid batter? If so you may need to add water to the appropriate levels for it to hold a charge after you put it on a trickle charger. Otherwise, I would say the battery is dead and you need to replace. Good luck!
Jul 30, 2011 | Yamaha XS 400 SE Motorcycles
Battery was dead and tried to start after charging, starter solenoid clicked and engine turn over slowly without starting. Now engine will not turn over. Battery is charged have power to all accessories...
okay,think of it this way,you tried starting,engine turned slowly,no start.....then you charged battery,engine wont turn over(although accessories work)WHY WAS THE BATTERY DEAD TO START WITH.Try a jump start(another battery)if it starts then you know what im going to say.....
Nov 06, 2010 | 2005 Ford Explorer
1988 Chev half ton kills battery. Put in new battery and starts right away. Ran it for about 20min then shut it off. Tried to restart and battery is completely dead. Needs boost to restart.
Have your starting system checked for starter draw.If the starter is drawing to many amps it will draw the battery down very quickly.Also have your charging system load tested to make sure the alternator is charging properly.Hope this helps.Good luck.
Mar 16, 2010 | 1988 Chevrolet C1500
Charged battery.showed charged right away.bike wont start unless
Hi and welcome to FixYa,
The description "...series of clicks..." is significant. The battery is not putting out enough current to turn the starter motor. The best way to determine the battery condition is to have it load tested. However, considering eveything else, it would almost always be a failed or about to fail battery.
Incidentally, the alarm has been designed to have minimal current drain when in standby.
Good luck and thank you for asking FixYa.
Jan 06, 2010 | 2006 Suzuki SV 650 S
Battery will not take a charge
are you sure the battery is any good? if the battery tests good then check the starter solinoid.
Mar 29, 2009 | 2006 Aprilia Leonardo 125
OWN AN '06 COMMANDER HEMI 5.7 CAR WONT START BUT HAS POWER TO ALL ELECTRICAL FEATURES MAKES CLICK BUT WON'T TURN OVER. TRIED TO REMOVE BREAKERS FOR STARTER AND STARTED UP AND DROVE BUT AFTER I STOPPED IT...
Check for power in and out of starter relay.Check power at starter (large terminal hot at all times, smaller one hot with key in start position.) Make sure battery terminals are clean ON inside where it matters and check connections on the other ends of battery wiring as well. Breaker should have continuity as well. If power is present at starter, likely starter has failed, but do not condemn till everything has been tested. I assume battery and charging system are in good condition?
Jan 12, 2009 | 2006 Jeep Commander
HP Pavilion ze4300 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
