Question about Ricoh SP C320DN AllInOne Laser Printer
Ricoh c320dn prints with black lines - Ricoh SP C320DN AllInOne Laser Printer
2 Suggested Answers
smt24
  • 54 Answers
SOURCE: lines in printed copy on Ricoh CL3500N
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored. The corona wires are also integrated into the toner cartridge in many smaller machines
Posted on Jun 05, 2009
Ricoh aficio 1800 .why copies are now black lines appear from top to bottom?
I guess you talk about Ricoh MP 1800.
The Black lines on the bottom appear because the copier has made more than 60,000 prints or more if new.
If it's bought used, than it has made 60,000 or more prints from the last change of the drum and the drum cleaning blade. For the print to be clean again, it will need to be changed the drum and drum cleaning blade. This copier as all other copiers have parts that have a yield.
Aug 25, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh printer aficio SP C320dn has an error code SP 397? any help?
542 an error in temprator .may be termistor dirty or defective.termostat or lamp check all.then reset by :c(yellow)-107-c(red.press 3 second)-then turn off and on
Jun 03, 2016 | Ricoh Aficio Office Equipment & Supplies
Rioch spc320dn Maintenance Kit #406794 It say replace the imager? What is the imager?
In a laser printer the 'Imager' is probably the same thing as the 'Image transfer drum' - this cylindrical unit has the Image of the page to be printed electrostatically set by the laser - this electrostatic image is then transferred onto the sheet of paper and electrically charged toner sticks to the page to form the image - the fuser then heats the paper and toner to fix the image and stop it smudging - The Image Transfer Drum will only be able to carry out this function a certain number of times and will need to be periodically replaced - in a business setting this could be within 1 - 2 years, in a home user setting it could last much longer - It depends on the volume of pages printed during the printer's working life
Feb 17, 2015 | Ricoh Aficio SP-C320DN - 26 PPM Color...
Ricoh aficio c420dn wont print black
Hi, my experience with this machine is that the gear that drives the black pcu breaks or cracks. Usually caused by the pcu being too hard to turn. I always turn the developer gear in the pcu before installing it just to loosen the toner.
Mar 15, 2017 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio SPC320 SP mode
hold down up and down for 5 seconds and then hit # -Carl
Jan 31, 2014 | Ricoh SP C320DN AllInOne Laser Printer
How do i get into service mode
Press the interuptkey(yelow) then press 107 and press and hold more 4 second Stop/clear(red)key.
Feb 06, 2013 | Ricoh SP C320DN AllInOne Laser Printer
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh SP C320DN AllInOne Laser Printer Logo
81 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
