Question about Minka Aire Ceiling Fan
I have a minka aire wall control- how do you reverse blades?
I need to reverse the blades so that I can push do the warm air. There is no reverse button on the wall control and I do not have a remote. We are new owners to the house and have no other info, no manuals and no remotes. The wall control only has on/off and low, med. and high buttons for the fan speed. Thanks
  • Adrienne Michaud Jan 14, 2013
    I am the one who posted question and forgot to mention ceiling in the room is 24 feet high, so can not access fan body, need to reverse using only wall control only if possible. thanks
4 Suggested Answers
  • 13 Answers
SOURCE: 2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Posted on Apr 23, 2010
alpug
  • 1961 Answers
SOURCE: Minka Aire Concept II Wet fan with remote control.
the electronic board of your fan must be check.there are triac transistors that switch the motor to it variable speed check the triac and replace it if you find it faulty.there 3 triac found on it these rae the switches of 3 speeds you can compare the resistance reading of all of the 3 triacs to determine which triac is faulty...good luck.
Posted on May 31, 2011
  • 11800 Answers
SOURCE: I recently bought a house
The reversing in a single phase AC motor is done by switching the flow of current thru the starting coil. For that to happen both ends of the coil must be accessible on the outside of the motor.
Unfortunately the motor in this fan doesn't have that so there is no way to install a reverse switch on it without extensive modifications on the motor: it will have to be opened, the starting coil identified, the captive end unsoldered from the main connector to which it is attached and extracted outside. From there the ends will have to be soldered on a special relay and wiring that would have to be inserted besides the usual wiring of the fan. From there a special command wire will have to be sent to the remote receiver board that you would have to insert it there also. To put it simply: the labor (which must be done by a pro) would cost more than a new fan.
So if you need a fan with reverse then just buy one: it will be way easier, faster and cheaper than to retrofit this one.
Posted on Aug 19, 2011
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
My Minka Aire ceiling fan has a wall mount remote and now will not reverse
call Minka Aire @ 1-800-307-3267. You might need a new receiver.
Sep 23, 2014 | Minka Dryers
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Sep 30, 2009 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Ceiling Fan Logo
53 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
