Question about OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A
Removing a air compressor on a n14 cummins - OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A
2 Suggested Answers
SOURCE: timing
to answer the first question:
the timing marks are on the accessory drive pulley. you will have an A, B, and C with a line at each one. you will line those up with the raised portion of the front gear cover. more likely than not, the letters are either painted over or rusted over, so they may be somewhat hard to spot. you will have to use a 1 5/16" socket to bar the engine over by the nut on the accessory drive pulley.
the second question: to removed the air compressor, you will need to disconnect all the lines going to and from the air compressor and fuel pump. this includes having to drain your coolant in order to disconnect the cooling lines to the compressor. you will need to remove fuel lines, air lines to the air governor, and anything else that may hang up. be prepared to replace any gaskets that you disrupt during this process, because they WILL leak if you do not. there are, if i remember correctly, 4 5/8" nuts that hold the air compressor on the accessory drive, 3 of them are relatively easy to get to, however the 4th, the one at the top closest to the block, must be removed with a special wrench, it is an S shaped wrench that you can buy from a snapon or matco dealer made specifically for that nut. once they are removed the compressor/fuel pump assembly should come right apart. if any damage is done to the accessory drive however, you must replace that as well, which could lead to a very large mess.
I myself work for Cummins, and have recently done this very repair for local cement company. I had to replace the accessory drive gasket due to a leak. Once the accessory drive was removed, I found that the accessory drive bushing in the gear housing had spun. That leads to a repair of having to replace the entire gear housing. To due so you must hoist the engine up and remove the front engine supports and removed that entire housing. So be warned, it may be a much more daunting task then it seems to appear.
Good Luck
Posted on Jun 25, 2009
2000 peterbuilt 379 cat where's the fuel pump located
Cummins N14 fuel problem Fix - YouTube
? 5:52
www.youtube.com/watch?v=YaFK-_ZbyBI
Jun 26, 2013 - Uploaded by Anderson E Rockefeller 98 Cummins N14 select plus for the past 6 months fuel pressure gauge keeped on ... I changed the injectors, fuel pump, turbo, and fuel lines. .... Read my other comment i left you also you need to replace the 90 degree check ..... N14 Cummins 2001 Peterbilt378 Hauling Scrap Metal Uphill - Duration: 4:15.
Aug 29, 2015 | Cars & Trucks
Diagram cummins n14
I don't know which diagram you need, but you will find all of them here: Cummins N14 Engines Service Manual Download
Jun 21, 2014 | Computers & Internet
Engine misfires on one cylinder.n14 cummins.
If you know which cylinder then test / replace the injector. Check the wires and connections for that injector.
Apr 03, 2013 | Cars & Trucks
S shaped wrench n14 cummins air compressor
I don't know what exactly do you need, but check out the service manual for any repair procedure you want to make.
Nov 29, 2012 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
Timing
Good Luck
Mar 26, 2009 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Logo
1,861 people viewed this question
Top OTC Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an OTC Hammering Expert? Answer questions, earn points and help others
