Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Access the menu options manually
How do i access the menu options manually? i dont have a remote for this tv
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
Posted on May 22, 2009
How can you access USB option on sharp LED tv without remote?
Some TVs has the manual control to menu down right, on frame. Did you check?
Else, only way is to get a GOOD universal remote. The one used for DirecTV has a control of SOURCE.
Check this manual
http://tv.manualsonline.com/manuals/mfg/directv/rc64.html
Jun 09, 2015 | Sharp LC-29LE440M Multi-System LED TV
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
Cannot access menu with remote, can i access menu manually ?
If there is a menu button on the TV then you can, but if it isnt working on your remote then there must be a problem with the remote. You can look at the manual that came with the TV for more information on that and if you dont have one heres a link to one: http://www.scribd.com/doc/34310286/Sharp-LC-32AD5E-BK
Aug 05, 2011 | Sharp LC32AD5EBK 32 in. LCD TV
My ECCO tv is locked<
Hello
Toshiba's Panel Lock feature allows you to save your settings on your television so that no one else may change them and only the On/Off switch may be utilized from the TV's front panel. Parents may find this option useful to prevent children from accessing programs containing violence and other inappropriate content. Once you turn this feature on, certain steps must be followed to turn it off again.
1. Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
2. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area.
3. Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Feb 17, 2011 | Toshiba 32A33 32" TV
NEC PlasmaSync 50MP2 50 in. Television But after looking at the manual I see that I am missing menu options (Option1-4 and Advanced OSM) How do I enable these. This is a hand me down and I've had to get a...
hi mate, did you sort this problem out, i have bought same tv but when u switch it on the rgb2 screen comes up and you cant change it by buttons at the bottom, i dont have a remote either.
what universal remote shall i get and how do i enable the buttons at the bottom
thanks.
fourteen0407@yahoo.co.uk
Jul 05, 2010 | NEC PlasmaSync 50MP2 50 in. Television
I cannot get closed captioning to turn off and stay off on my magnavox tv. the menu has no cc options at all. and the remote turning it off is onl,y temporary. any ideas?
I have the same problem, but I cant even get a code for my universal remote to access my menu or any of the settings. Dont think I will buy Philips/magnavox any more.
Oct 19, 2009 | Philips Magnavox 20MS233S 20" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Sep 09, 2007 | Zenith SY2751Y TV
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Aug 20, 2006 | Sanyo DS27800 27" TV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
393 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
