Question about Apple Ipad 16gb 3g Wi-fi Wifi Tablet A1337 Gen 1 1st Original Mc349ll/a G38
How to hard reset ipad a1337 16gb - Apple Ipad 16gb 3g Wi-fi Wifi Tablet A1337 Gen 1 1st Original Mc349ll/a G38
I don't know my password to Ipad need to hard reset
Can only be done via a computer that has iTunes on it. Log in with Apple ID, back up the device and then Reset.
If you know the password it can be reset via Settings.
Mar 23, 2017 | Tablets & eReaders
How to hard factory reset an apple ipad, don't have passcode
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. Reset iPadsettings.16 Apr 2013
Apple iPad hard reset
www.hard-reset.com/apple-ipad-hard-reset.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=hard%20reset%20an%20apple%20ipad
Nov 29, 2016 | Apple iPad Tablets & eReaders
How do I physically hard reset my ipad 2
A hard reset is to hold both the button on the right side of the top edge and the home button at the same time until the iPad goes dark, then you will see the white Apple logo in the middle of the screen.
Jan 22, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do I physically haard reset my ipad 2
Hard reset is usually power button and home button together five seconds or until screen blanks to small spinning circle icon.sometimes you need to hold the volume up button as well.
Jan 22, 2015 | Apple iPad 2 Wifi 16GB
How to hard reset ipad air to recognise another apple id
Go to Settings... / General
At the bottom of the list is Reset
You can do a full reset from there.
Oct 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Reset manually
This site may be helpful, but there are warnings to backup your data.
http://www.hard-reset.com/apple-ipad-2-hard-reset.html
May 18, 2014 | Apple iPad 2 Wifi 16GB
Frozen screen with clicking sound
As with many electronic devices that sport an operating system, there might come a time when your apps start wonking out or your iPad simply freezes. In most cases, a "hard reset" fixes most issues.
To do a hard reset, just hold the "Sleep/Wake" button on the upper right of your iPad along with the circular "Home" button on the lower middle part of the device's bezel. After 10 seconds, you should see the Apple logo. That's the sign that you've successfully pulled off a hard reset with your iPad.
Jan 26, 2014 | Apple iPad 32 GB 3G Tablet PC
Unfreeze ipad
hard reset, press power button on top and front button at the same time till it shuts down, 5-10 seconds, then turn on normally, if not fixed, hard reset, and do a restore from iTunes and your computer
Jan 13, 2014 | Apple iPad Tablets & eReaders
How to reset ipad
A little more information would greatly help in order to better answer your question. Why have you had to "hard reset" your ipad several times? What was the symptom or was it rebooting on it's own? But depending on what generation iPad you are running and what software you are trying to run. Lets see if we can get your issue resolved before having to take it into the shop :D
Nov 12, 2013 | Tablets & eReaders
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
Apple Ipad 16gb 3g Wi-fi Wifi Tablet A1337 Gen 1 1st Original Mc349ll/a G38 Logo
784 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
