I have a BWH30NLTC that started out working great with a nice blue flame, but now both the pilot and burner have a yellow/orange flame. I've cleaned everything with compressed air and changed the regulator but can't get the blue flame back. Any suggestions would be greatly appreciated. Thanks! Other than the yellow/orange flame everything else seems to be OK.
  • 32 Answers
SOURCE: Burner adjustment
HE PART YOU REFER TO IS THE BAFFLE, TURN IT UNTIL YOU GET A BLUE FLAME
Posted on Apr 08, 2008
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
AZSTALZ
SOURCE: charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Posted on Nov 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Posted on Jan 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Heatilator Pilot Issue
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
READ MORE
Posted on Feb 09, 2009
Orange pilot flame
Orange or yellow gas flame indicates air is not being mixed with the gas before burning.
The pilot burner has air holes to allow air to mix with the gas for efficient blue flame burning.
The air holes are probably blocked if the flame is approximately the usual length or longer. If it is significantly shorter it indicates the gas pressure to the jet is reduced.
Feb 07, 2018 | Heating & Cooling
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
I have a Vulcan Freeloader that is over 10 years old. The pilot does not stay lit when I release the red button. Also, the pilot flame is orange. What can be done as the main burner would not work when the...
The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. Hope this helps.
Jan 20, 2011 | Heating & Cooling
Hi, I have an early model Raypak AT and after switching/turning everything off for Winter, it now won't ignite the main burners - the pilot works but when I "turn it up" nothing happens not a...
Is your pilot light blue with no traces of yellow in the flame? If it has any traces of yellow in the flame the pilot assembly will need to be removed, disassembled and cleaned. If it has a blue flame, and the flame is hitting on the pilot mv generator (either a round rod or flat bar) you will probably need to replace the pilot mv generator.
Jan 09, 2011 | Pool & Spa
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
G4-7 atwood water heater lights great, heats water but when it cycles the pilot goes out no hot water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
May 10, 2010 | RTO Atwood Water Heater - 6 Gal LP
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
