Question about Lanier Ld228c Ld232c Ld238c Copier Fuser Unit
How do i change Lanier LD238C Fuser Oil Unit
I cant remove the old fuser oil unit
4 Suggested Answers
  • 990 Answers
SOURCE: Have a Lanier 5518 with a sc546 code, fuser
Hello sir; According the menual said, that's thermister open or power supply board, but before go that far why don't try to do a reset, steps as follow;
Press "clear mode", "107", then pres and hold down "clear/stop" key, then choice "copier SP" then enter "5810" press enter, select 1, then press"R/#" key and "original type" key at same time to reset, try it and let me know the result. after reset just turn power off and back on.
Posted on May 09, 2009
Testimonial: "Thanks for the help:)!"
SOURCE: How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
Posted on May 26, 2009
  • 990 Answers
SOURCE: SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Posted on Feb 02, 2010
How do I adjust print margin in service mode
I figure it can be done on the computer settings for the printer.
Jul 16, 2015 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
Ld238c replace fuser
Its a maint. light, no need to replace unless quality problem. -Carl
Mar 22, 2014 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
I have been advised of an error message on an Aficio 3800 series printer. I am told they need an 'Oil Fuser unit ' but as far as I can see the machine uses a Fuser Unit OR an 'Oil Supply...
The fuser uses an oil supply unit, which is changed separately from the fuser itself. The fuser oil supply unit (400549) is what is required.
You will find the manuals and other sueful details about this printer here.
Jul 07, 2011 | Ricoh Aficio AP3800C Laser Printer
I replaced fuser and fuser oil units do I need to add oil?
If the copier is a 1224c the fuser oil tank is in the back on the right side behind a cover. the oil goes in there and is sucked up to the fuser.
Feb 19, 2010 | Ricoh Aficio CL7000 Laser Printer
SC 571 error
Feb 02, 2010 | Lanier Office Equipment & Supplies
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh 7100cl
I belive this is the cartridge type oil unit. If you look at the top of the oil cart you will see 3 metal contacts.....clean these and look for where they make contact in the machine clean those and gentley pull down on them so that they make a little better contact this should clear your message provided there is oil in the carttridge
Sep 24, 2009 | Gestetner C7435n Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Lanier Ld228c Ld232c Ld238c Copier Fuser Unit Logo
173 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
