Question about Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
The lock appears to work the opposite way it should
    Problem Solver:
  • 7 Answers
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Posted on Jul 09, 2013
3 Suggested Answers
leafsveteran
  • 74 Answers
SOURCE: Kwik Set keyless entry lock. We
With the door open so u dont get locked out,did u remove the batterys and try to re-set your door code ?
Posted on Dec 18, 2010
SOURCE: I bought Rona Collections Electronic Deadbolt. My
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
Posted on Dec 28, 2011
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
How do you prgram remote keyless entry
Here are the instructions from the factory service manual:
1. Enter 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Sep 14, 2011 | 1995 Ford Crown Victoria
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK Logo
1,277 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Mark Wolfe
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
