Question about Dryers
Remove timer dial from dvt00 dryer
Need to change timer unit but can not remove dial at front to do so
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Usually a C clip behind the dial,pop it off
Posted on Jan 16, 2013
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Dryer does not heat--timer dial does not work either.
Hello Agnew77,
Chances are you have a bad or defective motor that rotates the dial and sequences the dry process..
Unless you are technical and able to troubleshoot this type of problem safely, you may want to remove and replace that motor assembly with another or have it serviced by an applince tech. Please advise if you want to attempt to troubleshoot this problem or order replacement parts online and I may be able to provide some assistance...
Regards,
Rick
Posted on Nov 22, 2008
SOURCE: I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm met
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Posted on Apr 22, 2009
heatman101
  • 43501 Answers
SOURCE: dryer will not start, removed
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 04, 2011
GE Front load Gas Dryer Model GTDP490GDOWS won't turn on
Remove the timer nob see if it is cracked, replace it with another nob or use pliers to turn the timer see if that works
Aug 26, 2014 | Dryers
How to remove timer knob from Kenmore washer, model #29422800
I can't remember if the timer has to be pushed in or pulled out to remove it, but the timer knob comes off by turning it in a counter-clockwise direction. Once the knob is off, the clear plastic dial underneath should pull off. There is a single screw under the dial that holds the timer in place. You can access the timer by popping the operator console up. There is a release tab in the front corner of the console on each side. Simply slide a putty knife under the console at each front corner and push straight in from the front. The console will lift up after each tab is released.
If you have questions, or need further advice, please let me know.
PS Is there a particular reason why you are trying to remove the knob? Do you suspect a defective timer? Some problems may give symptoms that make it appear to be timer related, but it may not. I just don't want you to spend money on a timer unnecessarily, if the problem is attributed to something else that is less expensive.
Feb 06, 2010 | Washing Machines
Went to push the dial in to start and it won't
first make sure you have power to the dryer.if you have power to the dryer than put your ear to the timer and see if you hear the timer running.if the timer is running than you nead to unplug the dryer and pull the dryer away from the wall so you can remove the vent hose and the back panal and the power cord cover.next look down and to the left and you will see a white plastic thermal fuse.remove the wires from the fuse and use a meter to see if the fuse is closed.if it is not replace the fuse and replace the back and power cord cover.plug the dryer in and check unit out.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
Timer not ticking,not starting
Hi. This will be the result of a failed timer motor. This mechanism is the main initiator of the unit. The unit will not operate properly, in this state. Proper current will not be directed correctly, due to the failed timer motor. The motor provide the forward advancement of the dial plate across the cogs. This is vital to optimal dryer functions.
The timer module must be replaced. Once replaced, the unit will return to its normal operating status.
NOTE_ Your door switch is not the culprit. The timer has failed.
Dec 14, 2009 | Roper REX4634KQ Electric Dryer
Washer does not change cycles on its own
timer is most likely bad if it will not move on its own at all..
3951703 - TIMER
you can access the timer by:
remove power from the unit.
remove the philips head screws that should be present in each left and right control panel end cap front.
slide the control panel bottom forward 1/2 inch and lift up.
the entire console will swing up on the hinges in the rear of the console top.
with the console upside down you can see the back of the timer, there is a small brown clip sort of recessed into the back of the timer that is connected to the timer knob/shaft. that clip needs to be pulled out so that the knob can be removed to access the screws on the front to remove the timer assembly.
around $100 new
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
Taking the front panel off.
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer
If this worked before that part was taken off, then take it off agin and make sure that the gear is engaged with the other gear in side the timer unit re adjust and before putting screws back in try turnning dial if it engages the put screws back in and if this fails you may need new unit (timer unit) That small gear may be pushing on the one it's suppose to engage.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
I have frigidaire electric dryer - drum turns - no heat - timer switch/dial does not advance
replace timer,,than see if it heats,,if you ran this unit with timer not moving,,you made need to change thermerstats
Dec 26, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
