Emerald aire remote for split system as12c1fd
Have a 18,000 btu amcoraire duo split unit and lost remote control how can you adjust temp without the remote
You can't adjust anything without the remote,
go to ebay.com search Amcoraire remote control, you will find what you need.
Jul 08, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
How to power on a rudd air conditioner without the remote
you sure 12000 BTU that small for split? if it is split system then it turn on off by the thermostat
Jul 10, 2009 | Heating & Cooling
The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Jun 20, 2009 | LG LSC121PMA Split System Air Conditioner
LG remote problem
Most probably if the remote works on the other units then the receiver on your problem unit is busted. You have to call an authorized service repair shopr to replace the board.
I hope it helps.
Jun 13, 2009 | LG LSC121PMA Split System Air Conditioner
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
A/c remote working but system wont respond
Heya Allhart?
How did you check the remote? Did you check the remote via viewing it on a LCD screen? If the remote is working than you need a new receiver PCB for your air con and would contact Sanyo to see if it is under warranty or for them to get someone out to veiw.
Hope this helps
Jan 01, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
318 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
